Activity › Forums › Web Design (WordPress, Joomla, etc.) › Vertical Spry Bar does not display propery in IE
  • Vertical Spry Bar does not display propery in IE
    Posted by John Replogle on April 25, 2012 at 2:28 pm
    I have been having trouble with my vertical spry bar. The bar displays correctly in Firefox but when it is tested in IE the submenus pop up at the top of the menu bar rather than inline with the submenu’s parent. My that Dreamweaver created for me is as follows:
    @charset “UTF-8”;
    /* SpryMenuBarVertical.css – Revision: Spry Preview Release 1.4 */
    /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
    LAYOUT INFORMATION: describes box model, positioning, z-order
    /* The outermost container of the Menu Bar, a fixed width box with no margin or padding */
    ul.MenuBarVertical
    margin: 0;
    padding: 0;
    list-style-type: none;
    font-size: 100%;
    cursor: default;
    width: 237px;
    /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: https://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
    ul.MenuBarActive
    z-index: 1000;
    /* Menu item containers, position children relative to this container and are same fixed width as parent */
    ul.MenuBarVertical li
    margin: 0;
    padding: 0;
    font-size: 100%;
    position: relative;
    text-align: left;
    cursor: pointer;
    width: 200px;
    /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
    ul.MenuBarVertical ul
    margin: -5% 0 0 95%;
    padding: 0;
    font-size: 100%;
    position: absolute;
    z-index: 1020;
    cursor: default;
    width: 8.2em;
    left: -1000em;
    top: 0;
    /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
    ul.MenuBarVertical ul.MenuBarSubmenuVisible
    left: 0;
    /* Menu item containers are same fixed width as parent */
    ul.MenuBarVertical ul li
    width: 100%;
    DESIGN INFORMATION: describes color scheme, borders, fonts
    /* Outermost menu container has borders on all sides */
    ul.MenuBarVertical
    border: 1px solid #CCC;
    /* Submenu containers have borders on all sides */
    /* Menu items are a light gray block with padding and no text decoration */
    ul.MenuBarVertical a
    display: block;
    cursor: pointer;
    background-color: #000000;
    padding: 0.5em 0.75em;
    color: #FFFFFF;
    text-decoration: none;
    /* Menu items that have mouse over or focus have a blue background and white text */
    ul.MenuBarVertical a:hover, ul.MenuBarVertical a:focus
    color: #FFF;
    /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
    ul.MenuBarVertical a.MenuBarItemHover, ul.MenuBarVertical a.MenuBarItemSubmenuHover, ul.MenuBarVertical a.MenuBarSubmenuVisible
    background-color: #999999;
    color: #FFF;
    border: 3
    SUBMENU INDICATION: styles if there is a submenu under a given menu item
    /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
    background-image: url(SpryMenuBarRight.gif);
    background-repeat: no-repeat;
    background-position: 95% 50%;
    /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a “hover” background image positioned on the far left (95%) and centered vertically (50%) */
    background-image: url(SpryMenuBarRightHover.gif);
    BROWSER HACKS: the hacks below should not be changed unless you are an expert
    /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
    ul.MenuBarVertical iframe
    position: aboslute;
    z-index: 1010;
    filter:alpha(opacity:0.1);
    /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
    @media screen, projection
    ul.MenuBarVertical li.MenuBarItemIE
    display: inline;
    f\loat: left;
    background: #FFF;
    Curtis Thompson replied 14 years, 5 months ago 2 Members · 1 Reply
