Activity › Forums › Adobe Premiere Pro › Vertical slide show with different height images Premiere Pro
  • Vertical slide show with different height images Premiere Pro
    Posted by Arnis Putnins on July 7, 2020 at 4:22 pm
    I am new to Premiere Pro. Cannot find solution to make vertically scrolling photo slide show with two different height images (like a film strip) so there is no background screen  visible. Need to make it so that many photos flow continuously one after another like glued together. Problem is that photos are in different height.
    I added Vertical Push Transition Effect, but smaller height image exposes black screen background (because it is shorter in height), which I need to avoid. Screen size is adjusted to the largest image size.  If someone has an idea or knowledge how to solve it would be great
    Arnis Putnins replied 6 years, 2 months ago 2 Members · 2 Replies
  • Andy Ford
    July 7, 2020 at 8:43 pm
    If you need to fit each photo into the same dimension frame and you want to avoid scaling up the smallest photos to cover the black, you can set your dimensions to be that of the smaller photos. On the larger ones, scale down until the height is the same as what you are looking for and this will just omit the periphery of the right and left edges. You can move the photo right or left in the frame in case there is action you need to see in either the right or left of the picture.
    Or, you can go in Photoshop (since cropping there is easier) and crop all your photos to be the same size. This way you can adjust them in the frame to center the action of the photo and chop off the excess and you’ll be dealing with the same size.
    Video Producer / Digital Marketer / Gear Reviewer / Author
    — http://www.AndyFordVideo.com —
  • Arnis Putnins
    July 8, 2020 at 11:43 am
    Thank you for extensive support Andy! Cropping will not be solution this time, because need to keep full size images and the cropped as they are. Withdrawal is the same, height is different. Also, the scroll is intended to go vertically, from bottom to top.
