Activity Forums Adobe After Effects vertical scrolling layer jumps backwards
  • vertical scrolling layer jumps backwards
    Posted by Daniel Monskey on February 13, 2021 at 7:09 am
    I have 3 side-by-side video columns intentionally scrolling upward in a screen frame. They shoot up to fill the frame, then slow down and move up as directed. Then, nearly right away, they move back down a bit (about 15 pixels), then they resume their intended speed and path upward again. The video is 1:05 in length, so it is short. I had the same problem with them in Premiere Pro too, so I thought I’d try a more savvy effects program to accomplish the same thing. AE is stumping me too. What might be causing this and how might I resolve it?
    Dan
    Eric Santiago replied 5 years, 7 months ago 3 Members · 4 Replies
  • Chris Voelz
    February 13, 2021 at 3:02 pm
    Look at the graph editor and play with your middle key frame. If you have easing applied it could be the result of that.
  • Daniel Monskey
    February 16, 2021 at 2:58 am
    WOW! THIS was immensely enlightening! It WAS whacked somehow and I was able to resolve the issue AND learn something entirely new as a result! You guys with this expertise are SO helpful and generous with your knowledge and time. Thank you for the help and thank you for monitoring the community! It’s like having creative angels watching over us struggling to make a mark.
  • Chris Voelz
    February 16, 2021 at 3:17 pm
    🙂 no problem. Creative Cow has bailed me out numerous times.
  • Eric Santiago
    February 16, 2021 at 4:05 pm
    The beauty is that you are dealing with tech that is across almost all animation apps.
    Read up on linear, bezier, ease blah blah blah.
    It’ll do you good 🙂
