Activity Forums VEGAS Pro Vertical lines appear on rendered video
  • Vertical lines appear on rendered video
    Posted by Bruno Cortés on August 31, 2021 at 1:42 pm
    Hi, I am editing a video in sony vegas 17 in which I am trying to make a handshake effect, so I used the saphire pluggin s_shake to simulate it and it seemed to work pretty well until I rendered and noticed this lines
    Here is a small clip of the video where you can watch the lines in action : https://drive.google.com/file/d/1t-g58dhyZQ3K65R_EuZKg1nhFEFNesYS/view?usp=sharing
    This lines seem to appear to be on the place that the camera would be if I did not used the s_shake effect, specially on the left and right sides of the screen.
    I ‘ve been looking for a solution to this problem and I don’t seem to find anything about it, so that’s why I’m here looking for help.
    I am using a computer with an nvidia 1060.
    An intel I7 and 16gb of ram.
    I am using a windows 10 machine,
    Thanks in advance and thanks for reading
    John Bolton replied 5 years ago 2 Members · 3 Replies
  • John Bolton
    August 31, 2021 at 2:52 pm
    Have you tried to Disable Sampling
    You can set your main properties with the Resample mode or on the time line with opposite mouse on the item that is causing the problem. This effect always seems to happen with animation.
  • Bruno Cortés
    August 31, 2021 at 3:41 pm
    Thanks John!
    I did try that before, and it did not work 🙁
    Do you have any other idea of what might be causing the lines to appear?
  • John Bolton
    September 1, 2021 at 7:28 am
    Did you apply it to all the fast moving animation. ? Can think what else it could be at the moment.. Is the moving figure an animated Gif?
