Activity › Forums › Adobe After Effects Expressions › Vertical Justification in After Effects
  • Vertical Justification in After Effects
    Posted by Christian Kiedrowski on October 14, 2021 at 8:03 pm
    There is a tool in InDesign called Vertical Justification in the “Text Options” (<b style=”font-family: inherit; font-size: inherit;”>⌘+B) where you can align your text within a bounding box to the Top, Center, or Bottom.
    I’m wondering if there is a way or expression that I could use to go about automating this same feature in After Effects? Calling on all the great expressioners out there to see if it’s possible!
    Kevin Camp replied 4 years, 11 months ago 2 Members · 1 Reply
  • Kevin Camp
    October 14, 2021 at 8:17 pm
    Using sourceRectAtTime() makes this pretty simple.
    Vertically center:
    rect = sourceRectAtTime() ;
    y = rect.top + rect.height / 2 ;
    [ value[0], y ]
    Align bottom:
    y = rect.top + rect.height ;
    [ value[0], y ]
    Apply either of those to the anchor point property of the text layer.
