Activity Forums Adobe After Effects Vertical / horizontal distortion fixing
  • Steve Bentley
    April 6, 2018 at 5:40 pm
    There are a couple of approaches depending on footage.
    First there’s the Optics Compensation under Distort. This one is to help overcome lens distortion imparted on the footage by particular cinema lenses. (you can also use it to impart a distortion on footage so it looks like it was shot with a real lens).
    The second way is the bezier warp tool. Both these solutions assume there is an overall warp to the image that needs correcting.
    The last way is more fine-tooth-comb. – the reshape effect. You place paths across the image that match your distorted geometry and then duplicate those paths and reshape them so they are right.
    None of these add significant time to the render.
    There are also the mesh deformer and corner pin effects but both of these are either annoying to use or produce a softer image than they should. CC corner pin or Power pIn produces a much superior image.
