Vertical Black Lines on Frames
I am creating an intro for a travel video that superimposes moving frames (the moving frames are active video themselves).
The problem is that the moving video frames, about half the size of the main video portion, exhibits vertical black lines bordering the right and left sides of the frame (the top and bottom edges are fine). I would like to have the edges of these moving frames clean all the way around (no black edges). How do I accomplish this?
When I view the moving frames within the Event Pan/Crop window, the vertical black lines are there. I cannot crop them out this way because the frame is constant.
I included a still with yellow arrows pointing to the unwanted vertical black lines. Very much appreciated if you could show me how to eliminate these. Thanks!
