Activity Forums Adobe After Effects Vertical Bars growing?
  • Vertical Bars growing?
    Posted by Gabi Bucataru on February 22, 2014 at 4:17 am
    Hi Gang!
    Really quick. How would you go about having about 5 vertical bars (at 20px) growing from the bottom of the screen up?
    I thought about using paths and stroke effect than animating the end for each.
    But something is telling me that there are easier ways, like having the 5 bars drawn and simply animating a mask.
    The real question is how to draw those bars evenly shaped?
    I might be staring at the obvious, but here it os.
    thanks much!
    gabi.
    Jason Jantzen replied 12 years, 7 months ago 3 Members · 2 Replies
  • Joseph W. bourke
    February 22, 2014 at 2:18 pm
    First create a new layer, and make it the size and proportions you want it. Second, animate the vertical scale of the layer (uncheck the proportional link) to your liking. Third, duplicate the layer four times, and move the dupes to where you want them on the screen. Done. If you want the animation offset, then change the layer spacing on the timeline.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Jason Jantzen
    February 22, 2014 at 5:57 pm
    After you’ve created your layer like Joe described, if you want to space them evenly, you could take advantage of the align and distribution tools, or you could use this fun script called Array which creates copies in an array based off of any transform property https://aescripts.com/array/
    Jason Jantzen
    vimeo.com/jasonj
