Activity › Forums › Adobe Premiere Pro › Versioning a Sequence that contains Nests
  • Versioning a Sequence that contains Nests
    Posted by Dustin Parsons on April 30, 2014 at 7:35 pm
    I come from FCP 7 where any nests created in a sequence are duplicated along with the sequence so it’s easy to lock down a version that was delivered to a client with the confidence that it won’t change while working on a new version. In Premiere Pro, every time I duplicate a sequence to make a new version the nests link back to the original nests so if I decided to change a nest in version 3 it also changes in version 1 and 2 even if I have all tracks locked in those sequences.
    Is there something like True Comp Duplicator for Premiere Pro?
    How do you like to version a sequence in PPro that has nests?
    Rob Combs replied 6 years, 9 months ago 5 Members · 6 Replies
  • Alex Udell
    April 30, 2014 at 9:21 pm
    That’s an excellent point.
    I don’t think that exists.
    It should be an option and you should be able to set the default to your preference.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Conrad Olson
    May 1, 2014 at 7:07 pm
    I had the same issue on my latest project. I ended up un-nesting the sequences.
    I’d definitely like that feature.
    conradolson.com
  • Alex Udell
    May 1, 2014 at 7:20 pm
    Not that you should HAVE to do this…
    but IN a clean project if you import the sequence (via the browser I think)…
    you can get all the dependent sequences too AND it’s not destructive to the originals….
    so you can work around it…
    Alex Udell
  • Dustin Parsons
    May 1, 2014 at 7:40 pm
    Adobe Feature Requests
    Let’s get this implemented in the next update! …or the update after that.
  • Walter Soyka
    May 1, 2014 at 8:29 pm
    Let’s not just FR “true sequence duplication” — let’s FR direct scripting support and documentation for Premiere so that we can implement a feature like this ourselves.
    Walter Soyka
  • Rob Combs
    December 15, 2019 at 5:39 pm
    I’m really starting to think that Adobe doesn’t listen to user Feature Requests. When was this suggested, 2014?
