Activity › Forums › DaVinci Resolve › Version 9 and JPEG2000
Posted by Robin Erard on December 4, 2012 at 4:19 pmHello,
I would like to know if Blackmagic will implement JPEG2000 output (in XYZ DCI color space) ? It would be a very useful tool because most of the films I graded during this last year are for DCP, it means that I used DPX only to convert them in Jpeg2000. Anyone else thinks that would be a good option ?
Best
Robin
réalisateur, scénariste, monteur, étalonneur
http://www.robinerard.chDavid Baud replied 13 years, 9 months ago 3 Members · 5 Replies -
Sascha Haber
December 4, 2012 at 5:48 pmYou know how long it takes to render to XYZ converted JPG2000, right ?
Around 9 hours..
I prefer to leave the DCP encoding to the specialists and provide them with something also suited for REC709 projection, internet and data streams ready for a regrade.A slice of color…
Resolve 9.0.4 OSX 10.8.2
Colorist / Aerial footage producer
https://vimeo.com/saschahaber -
Robin Erard
December 4, 2012 at 6:47 pmHello,
I know… I make DCP with easyDCP creator + since two years. It’s not so long to render in JPEG2000, that’s why I was thinking about add this feature in DaVinci.
Best
Robin
http://www.robinerard.ch -
David Baud
December 5, 2012 at 3:50 am[Robin Erard] ” It’s not so long to render in JPEG2000″
I am curious about your statement here… could you give us an idea of rendering time with the spec. of your system? I have never done a DCP myself before, but I just had one done recently and I understand the lab we used have a render farm to speed up the process. I have read a single fast computer system could process 2K film into JPEG2000 @ 1 frame/second. Which is still 36 hours of rendering time for a 90 min. film!
If it is the case I am not sure I see the advantage to use Resolve for that purpose. In any case wouldn’t it make more sense to keep an uncompressed output master from DaVinci for keeping the delivery choices open without taxing Resolve?
David Baud
Post & VFX
KOSMOS PRODUCTIONS
Denver – Paris
http://www.kosmos-productions.com -
Robin Erard
December 5, 2012 at 8:20 amHello,
I made a test for you this morning :
INPUT:
DPX 1920×1080 REC709
5760 frames
at 24fps = 4minOUTPUT :
JPEG2000 XYZ8’30” to do the job, then about twice the duration.
My computer : MacPro 2×2.26GHz Quad-Core Intel Xeon
16Go 1066 MHz DDR3The process for the last feature I encoded (1h30 – 1.85 1998×1080) was less than 3h30 hours.
Best
Robin
David Baud
December 5, 2012 at 3:55 pm[Robin Erard] “My computer : MacPro 2×2.26GHz Quad-Core Intel Xeon
16Go 1066 MHz DDR3The process for the last feature I encoded (1h30 – 1.85 1998×1080) was less than 3h30 hours.”
Thank you Robin for your test and the information: I guess I was quite off base with my timing 🙂
Good to know! I am wondering if EasyDCP creator is faster than some other solutions out there?Merci,
David Baud
Post & VFX
KOSMOS PRODUCTIONS
Denver – Paris
