Activity Forums Boris FX version 6.0.6 with Avid keyframe issue
  • version 6.0.6 with Avid keyframe issue
    Posted by Paul Strilka on December 4, 2009 at 1:34 am
    Certain effects are not holding keyframe settings.
    For instance- a light sweep effect will hold any re-position keyframes- but not a change in the intensity. Any previous keyframe setting gets wiped out by new keyframes. Resulting in all the keyframes set to whatever the last keyframe is set to. What could be causing this?
    Matt Mullen replied 16 years, 9 months ago 3 Members · 2 Replies
  • Boris Yamnitsky
    December 4, 2009 at 12:35 pm
    Not sure but we’ll investigate.
    Boris Yamnitsky
    BorisFX
  • Matt Mullen
    December 4, 2009 at 2:12 pm
    This issue here may be that the parameter is not actaully getting keyframed.
    For some reason the default in Avid is to add a keyframe to active groups.
    If you right click(simply click for Mac) the add keyframe button in the effect editor you should be able to set it to all parameters or active paramater and then add the keyframes you need. with the adjustments.
    -Matt
