Activity Forums VEGAS Pro Ver 10 Render Times
  • Ver 10 Render Times
    Posted by Bill Mash on October 31, 2010 at 1:12 pm
    I’m experiencing render times with 10.0 that are 4X longer than 8.0c
    I used two test files a 10-second *.mts and a 2-second *.avi with the same results. I tried…
    Uninstalled Boris FX
    Uninstalled Wax
    Uninstalled Vegas 10
    Re-Installed Vegas 10
    Anyone else experiencing this?
    Cheers
    ~Just because you can doesn’t mean you should~
    Bill Mash replied 15 years, 10 months ago 2 Members · 6 Replies
  • John Rofrano
    October 31, 2010 at 1:57 pm
    Why don’t you give us a little more information and we can test with you:
    1. What are your project properties?
    2. What are the properties of the files (HD-1080i, HD-720p, SD)
    3. What render templates are you using.
    I’d be happy to run them through Vegas Pro 8, 9, and 10 to see if there is any difference.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bill Mash
    October 31, 2010 at 5:42 pm
    Thanks for the help John!
    The media, project and rendering settings are contained in the links below.
    Source Media:
    https://f1.creativecow.net/1234/test-file-v10-render-issues
    I re-sized the media on the timeline to 2-seconds and applied a chromakey using the color dropper and clicking on the leaves in the lower-left. FX in both versions are default.
    Project Settings
    https://f1.creativecow.net/1235/rendering-isses-project-settin
    The results are the same when using rendering to MPEG2 using the
    Blu-ray 1920X1080-24p, 25-MPS stream template.
    Thanks again! – Bill
  • Bill Mash
    October 31, 2010 at 9:23 pm
    Performed a more detailed analysis including using a more-standard rendering scenario. Rendered to MPEG2 HDV 1920X1080-24p 25MPS, the first 30-seconds of a multi-layered production project. In Summary Vegas-10 simply isn’t utilizing system resources properly. The shorter test-clips show a more dramatic difference as it wasn’t until 30% into the render before system resources started to spike up. At that point vegas estimated 13-minutes to complete.
    Vegas-10 = 6:20
    Production Clip 30-seconds
    ~60-avg-CPU-Usage +565MB PM + 550MB VM
    Vegas-08 = 4:25
    ~80%-Avg-CPU-Usage + 850MB PM + 900MB VM
  • Bill Mash
    October 31, 2010 at 10:12 pm
    Using the HD rendering test from the Sony board was helpful, including seeing at least one poster experiencing similar issues.
    https://www.sonycreativesoftware.com/forums/ShowMessage.asp?MessageID=526098
    07:09 — V8.0c
    12:20 — V10.0
    My system simply never get’s out of 2nd gear in V 10.0. In V8.0c my processor cranks into the high-eighties early on and utilizes more than twice the physical and virtual memory throughout the render.:-(((
    OS:Windows XP 32-bit
    OS Drive:7,200 rpm raid 1 scsi 250gb
    Edit Master: G-Drive Mini_Raid 1 250gb
    Edit Output: G-Drive Mini 250gb.
    MB:Pentium Dual Core 3.2 GHZ (64-bit capable)
    MEM:4GB of Ram, 3.37gb addressable.
    Display:NVIDA GT-430
  • John Rofrano
    November 1, 2010 at 1:31 am
    Your setting are confusing. The media file you posted is 60i yet you are setting your project to 24p with deinterlace set to none. This is incorrect and will cause interlacing artifacts in your output if you pan left or right.
    I also can’t follow what you’re doing with the chroma key. You’ll need to post a project file if you expect us to do exactly what you did.
    Here is what I did:
    Set my project to HD 1080-24p
    Dropped the file you posted onto the timeline
    Rendered to MPEG2 HD 1080-24p Blu-ray 25Mbps
    Here are my findings:
    Vegas Pro 8.0c 32-bit: 55 seconds
    Vegas Pro 9.0e 32-bit: 59 seconds
    Vegas Pro 10.0a 32-bit: 46 seconds
    Vegas Pro 10.0a 64-bit: 44 seconds
    So my findings are that Vegas Pro 10.0 renders faster than Vegas Pro 9.0 or 8.0 in that scenario.
    ~jr
  • Bill Mash
    November 1, 2010 at 5:08 am
    I’m in the process of upgrading my workstation motherboard and CPU to an AMD Phenom 6-core CPU with a clean install of Windows 7 64-bit. Hence it’s really not worth chasing this issue any further as my current configuration has seen it’s last production render.
    Thanks for all the help.
