Activity Forums VEGAS Pro Velocity Envelope mess
  • Velocity Envelope mess
    Posted by Tobin Bell on October 26, 2014 at 1:10 pm
    Hi there,
    I know using Envelope won’t shorten or lengthen the duration of the selected chunk. What I don’t understand at all why there’s NO ANY hotkey (pressing down CTRL or something) to make this happen?
    I finally finished to cut and edit my movie from a serious amount of pieces. It took 50 minutes. Now I want to set the speed and I should use the velocity envelope tool because the “drag right edge and move” doesn’t support speed span steppings. I need different speeds even in one chunk. So whatever I do if I set the envelope line it will mess the end of the piece (even if they all grouped up) so I have to re-cut the whole movie again? Basically I just wasted all my editing work here then?
    Or there’s any workaround?
    Tobin Bell replied 11 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
