Activity Forums VEGAS Pro Velocity Envelope Help Needed
  • Velocity Envelope Help Needed
    Posted by Jonathan Hay on February 26, 2006 at 4:00 pm
    I have a 30 second clip. I want to speed up some of the clip and slow down other areas of the clip. This is very easy to do in vegas with the velocity envelope. However, if I want my clip to end on a certain frame (and still be 30 seconds) is there any easy way for me to do this without trial and error. That is I want to hold the fist and last frame and then make a bunch of points which are adjustable but don
    Jonathan Hay replied 20 years, 7 months ago 2 Members · 2 Replies
  • Terry Esslinger
    February 26, 2006 at 4:28 pm
    You will add frames (length)by slowing down and remove frames by speeding up. If you do equal amounts of both (at differet points :>)
    your clip should remain the same length. By expanding the time line to make small changes easier to work with, you could place a node just after the first frame and just before the last frame and bring each to ‘normal speed. But you would not notice this visually (It would be like a subliminal change) To notice it visually I would think that you would need at least 10-15 frames (1/2 second)
    I hope this helps.
    Terry Esslinger
  • Jonathan Hay
    February 26, 2006 at 7:40 pm
    I would like to add my point to a frame not to a time so I can visually see it how close I am. I think you are still saying that this is a trial and error process. This is OK I was just hoping there was a better way.
