Activity Forums VEGAS Pro velocity envelope
  • velocity envelope
    Posted by Rick Wise on May 13, 2008 at 1:17 am
    I’ve lost the ability to see the video envelope, even though View/show envelopes is checked. When I insert a velocity envelope, there no longer is a blue line to adjust.
    This happened after I went to tools/options/customize keyboard and then to Global/velocity envelope and set a keyboard shortcut to make that happen. But, I discovered, the shortcut added a velocity envelop to the top video track even if I had highlighted a lower track. So I removed the shortcut — and lost the ability to see the envelope.
    Solutions?
    Rick Wise
    director of photography
    Oakland, CA
    http://www.RickWiseDP.com
    email: Rick@RickWiseDP.com
    Rick Wise replied 18 years, 4 months ago 2 Members · 3 Replies
  • Edward Troxel
    May 13, 2008 at 12:57 pm
    You might try holding CTRL-SHIFT when starting Vegas which will reset it back to factory defaults. You’ll then have to re-make the preference changes you’ve made since then.
    Edward Troxel
    JETDV Scripts
  • Rick Wise
    May 14, 2008 at 12:12 am
    Thanks, Ed. I think first I’ll try setting the keyboard options back to factory settings (I think I can do that.) If that doesn’t do it, I’ll go to the more extreme of resetting everything back.
    Rick
    Rick Wise
    Oakland, CA
  • Rick Wise
    May 15, 2008 at 5:11 pm
    It turns out that the problem is you need to check TWO settings for video velocity display:
    –View/show envelopes (be sure there’s a check mark)
    –View/video envelopes — be sure all are checked, especially “velocity”
    Rick Wise
    Oakland, CA
