Activity Forums Apple Final Cut Pro Legacy Veiwer white with crosshairs
  • Veiwer white with crosshairs
    Posted by Justinh on June 20, 2005 at 3:53 am
    My viewer is white with crosshairs. When you stop the playhead you see a frame, but whenyou play, it goes white with crosshairs. Weird? Sure. Any clues would be great…
    Peter Wiggins replied 21 years, 2 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 20, 2005 at 2:25 pm
    White video playback usually points at codec problems. Might reinstall QuickTime to fix this. is this DV or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Peter Wiggins
    June 20, 2005 at 4:50 pm
    Wireframe turned on? Looking at the alpha and not the video?
    It is easy to press keys accidentally!
    Check those then as Jerry says as Quicktime reinstall
    Peter
    https://www.peterwiggins.com
    At Wimbledon editing for ESPN
