Activity Forums VEGAS Pro vegs 9 mp4 render playback issues
  • vegs 9 mp4 render playback issues
    Posted by Sean Masi on February 14, 2010 at 6:04 am
    Using sony vegas 9 pro. Rendering with main concept mp4 and default template. After rendering completes and I playback my video it is clear that it has problems. If I do not touch the video and let it play from start to finish there are no issues. But, if I try to start or skip around in the timeline the video restarts from the beginning while the audio continues to play. This causes a loss of synchronization between audio and video.
    The issue does not occur with any other rendering options. Unfortunately I need this video to be in the mp4 format.
    Any help or suggestions would be greatly appreciated.
    -Sean
    Sean Masi replied 16 years, 6 months ago 3 Members · 4 Replies
  • Bob Peterson
    February 14, 2010 at 2:06 pm
    It sounds like the problem is in your playback software since the render can play correctly.
  • Sean Masi
    February 14, 2010 at 6:58 pm
    When rendering with any codec OTHER than the mainconcept mp4 playback is ok. But when rendering with mainconcept mp4 playback is not okay. My playback software is QuickTime and virtual DJ. I’m remixing music videos and need the format to be h.264, relatively low file size, and excellent audio.
  • Sam Caino
    February 18, 2010 at 3:04 pm
    I had this same problem. It is a issue specifically with version 9c and Sony is aware of it. The longer your .mp4, the worse the problem is. The video will play back fine in VLC player, however.
    I contacted Sony about this and their solution was to revert to Vegas 9b until they can fix the issue. I did this and the issue was fixed.
  • Sean Masi
    February 19, 2010 at 8:07 pm
    Your a life saver!!!! Thank you so much. Sony couldn’t help and I’ve been looking for this fix.
    It works great now!!!
    Thank you
