Activity Forums VEGAS Pro Vegasaur Transcoder Issues
  • Vegasaur Transcoder Issues
    Posted by Jay Mitchell on February 28, 2019 at 8:14 pm
    I need help solving a Vegasaur Transcoder Issue.
    I am adding regions from the timeline as I usually do.
    After loading the regions, the “OK” Check mark button on bottom of window is not active.
    I can select the Rendering Tab and select a Rendering Format from the list, But the “OK” Check mark button on bottom is still inactive and renderer won’t take. And of course, the output won’t take and the Render Button is Inactive.
    If anyone knows a solution, please let me know asap.
    Jay
    Aleksey Tarasov replied 7 years, 6 months ago 2 Members · 2 Replies
  • Jay Mitchell
    February 28, 2019 at 10:38 pm
    Solved!
    It is not good enough to just click / “highlight” the preferred Rendering Format.
    The “check mark” next to the format must also be highlighted.
  • Aleksey Tarasov
    March 1, 2019 at 8:54 am
    Glad you figured it out!
    Checkboxes allow you to select multiple renderers in one step.
