Activity Forums VEGAS Pro Vegas / Youtube Pixelation
  • Vegas / Youtube Pixelation
    Posted by Rick Potter on May 10, 2017 at 3:52 pm
    I’ve been fighting the Youtube Pixelation issue for years. Has anyone figured out whats causing it? I’ve tried all the suggestions/settings/render/format and whatever else you can think of.
    Pixelation is really bad on fast movement in textured areas like grass. Also using Video Velocity is a mess with regard to the same issue.
    Internet speed – 150 mbps
    Computer – 5820k, R9 390, 32gb, SSD for OS and Vegas, 4tb black.
    Do DaVinci Resolve renders exhibit the same problems when uploaded? I see lots of fast motion videos on Youtube that don’t have the pixelation problems and wonder what their solution is.
    Comments appreciated. Rick
    Francois Blawat replied 9 years, 2 months ago 5 Members · 6 Replies
  • John Bolton
    May 10, 2017 at 4:26 pm
    Can you provide us with the Media format you are using and what render settings.
    If you use the utility called MediaInfo https://mediaarea.net/en/MediaInfo , let us know what the various details are.
    With this it will be clearer as to the issue as normally most YouTube videos are relatively pixelated free..
  • Rick Potter
    May 10, 2017 at 6:21 pm
    Thanks for the response. Mediaarea is really neat! Here is my youtube video that has pixelation. I see other drone videos that don’t have the pixel blur, so I know it can be done. Comments appreciated. Rick
    https://youtu.be/tZVuzq_tgJI
    Mediaarea info from original file from my Q500 drone. 1080 60p
    11349_sourcemp4fromdrone.txt.zip
    Mediaarea info from rendered Vegas 13 file then uploaded to Youtube:
    11350_renderedfileuploadedtoyoutube.txt.zip
    Original Drone file data:
    General
    Complete name : E:\Missile base and #8 golf course\Source.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp42/isom)
    File size : 1.76 GiB
    Duration : 5 min 0 s
    Overall bit rate mode : Variable
    Overall bit rate : 50.3 Mb/s
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=30
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Source duration : 5 min 0 s
    Bit rate mode : Variable
    Maximum bit rate : 50.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 (59940/1000) FPS
    Original frame rate : 59.940 (60000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Source stream size : 1.72 GiB (98%)
    Title : Yuneec AVC
    Language : English
    Color range : Full
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    mdhd_Duration : 300437
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Bit rate mode : Constant
    Nominal bit rate : 128 kb/s
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 spf)
    Compression mode : Lossy
    Source stream size : 1.63 MiB (0%)
    Title : Yuneec AAC
    Language : English
    mdhd_Duration : 300523
    Rendered file from Vegas 13 uploaded to Youtube file data:
    General
    Complete name : E:\Missile base and #8 golf course\#8 golf Course.mp4
    Format : MPEG-4
    File size : 144 MiB
    Duration : 53 s 370 ms
    Overall bit rate : 22.6 Mb/s
    Encoded date : UTC 2016-10-02 18:09:50
    Tagged date : UTC 2016-10-02 18:09:50
    Video
    Format : AVC
    Format profile : High@L4.2
    Muxing mode : Container profile=High@4.0
    Codec ID : avc1
    Bit rate : 22.3 Mb/s
    Maximum bit rate : 26.0 Mb/s
    Frame rate : 59.940 (60000/1001) FPS
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.179
    Stream size : 142 MiB (99%)
    Language : English
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 53 s 355 ms
    Bit rate : 320 kb/s
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Stream size : 2.04 MiB (1%)
    Language : English
  • John Bolton
    May 12, 2017 at 7:34 am
    is it possible to take short video with your drone ( maybe a couple of minutes fast and slow moving ) and upload it so I/We can download original video and have a close look at it.
  • Danny Hays
    May 14, 2017 at 8:48 pm
    I’ve seen posts about this problem many times. Mostly with gamer’s that use a really high frame rate screen capture app. Have you seen any 1080 60p youtube videos with that much detail, (Green landscape) with that kind of fast motion without pixelization issues? I suggest you make several 30 second samples rendered at different formats and bitrates, then upload each and see which gives you the best results. Also are you downloading the youtube videos with this problem to see if it’s a streaming issue. Hope this helps, Danny Hays
    Danny Hays
    Samples of my Work can be seen here:
    https://www.youtube.com/user/ErnestDaniels/videos?view_as=public
  • Kim Durecki
    June 13, 2017 at 12:07 am
    I have been fighting pixalation with youtube recently. I found a fix for me. I render the video at the highest bitrate possible- then I download this file into youtube- youtube will always degrade the original file but using the highest quality rendered video helps ALOT!
    I have also then taken that high bitrate video and then used handbrake and downsized it- that also helps.
  • Francois Blawat
    June 24, 2017 at 11:10 pm
    I am wondering if anyone has used this Free plugin for Vegas that works under Vegas Pro 8 – 13?. It is called the Video4YouTube located here: https://vegasaur.com/Video4YouTube This is created by the author of the Vegasaur Toolkit Plugin program.
    I have not used this myself, but since it is free, I wonder if this will help alleviate some issues users are experiencing. Plus, what is the worst? If this does not work you can always uninstall it.
    Hopefully this works.
    FixitMad
