Activity › Forums › VEGAS Pro › Vegas work before DVD work
  • Vegas work before DVD work
    Posted by George Lemos on November 30, 2009 at 8:53 pm
    I’ve been doing some reading inside of Sony Vegas 9 and DVD Architect 4.5. I’ve picked up a pretty good feeling to start putting something together. I have some questions on the Vegas side before I render.
    The video I have is 1920×1080 recorded on an HD camcorder. Obviously the quality will be less going to DVD as I am not recording to blue ray but I want to render and burn this to as good quality as possible.
    I choose MainConcept MPEG-2 to save the file. Now under templates I see “DVD Architect NTSC Video Stream” and “DVD Architect NTSC WIDESCREEN Video Stream” as my options. From the description field I don’t see much of a difference. What should I use?
    Should I select on the option “Stretch video to fill output frame size (do not letterbox)” or would that be taken care of with the options above?
    When processing AC3 audio file I see “Dolby Digital AC-3 Pro” and I read you must click on custom, go to the “Preprocessing” tab, and change both “Line mode profile” and “RF mode profile” to None to make sure the audio is not too low. However the templates are “Default Template” and “Stereo DVD”, does it matter? They seem to have same description.
    Lastly, does it matter what DVD media I burn to? DVD+R, DVD-R?
    Theo Van laar replied 16 years, 10 months ago 2 Members · 1 Reply
  • Theo Van laar
    November 30, 2009 at 11:06 pm
    Are you working with Vegas 9Pro and DVDA Pro 4.5? Then you can get a free update to DVDA Pro 5.0.
    The difference between DVD Architect NTSC Video Stream” and “DVD Architect NTSC WIDESCREEN Video Stream is the pixel/aspect ratio, which determines whether you are working in widescreen or not. Choose the one that fits with your footage AND your project settings (which I assume is widescreen).
    About the AC3: tjis is what terry Esslinger recently wrote:
    https://forums.creativecow.net/readpost/24/901990
    And DVD + or – ? I always use plus and have no problems.
    Theo
