Vegas Won’t Render At All
Posted by Ken Bennett on November 6, 2010 at 4:14 pmThis morning my Vegas 9.0e will not render at all. says I’m running low on memory. I have nothing else running on the system. Why after months and months of no memory problems it suddenly appears?
What to do?
Thanks.
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures!Nigel O’neill replied 15 years, 10 months ago 4 Members · 3 Replies -
Steve Rhoden
November 6, 2010 at 4:30 pmTry uninstalling Vegas then do a general disc and registry cleanup…
then reinstall it.
Dont sweat it, this process wont take more than 20 minutes.Steve Rhoden
(Cow Leader)
Creative Arts Director and Film Maker.
Project Samples at:
http://www.youtube.com/hentys -
Stephen Mann
November 6, 2010 at 10:48 pmLow Memory or Out of Memory does not mean “Not enough RAM”, though adding RAM can sometimes fix a “Low Memory” waning. A “Low Memory” warning usually means that you have exceeded your commit limit. You need either a bigger page file, more physical memory, or both.
One of the biggest sources of confusion over memory usage is the whole concept of virtual memory compared to physical memory. Windows organizes memory, physical and virtual, into pages. Each page is a fixed size (typically 4 KB). To make things more confusing, there’s also a page file (sometimes referred to as a paging file and dynamic RAM). Many Windows users still think of this as a swap file, a bit of disk storage that is only called into play when you absolutely run out of physical RAM. In versions of Windows starting with Vista, that is no longer the case. The most important thing to realize is that physical memory and the page file added together equal the commit limit, which is the total amount of virtual memory that all processes can reserve and commit.
All Windows since XP (and Unix/Linux for that matter) always wants to have page space. Always. Programs like to and are allowed to pre-allocate as much memory as they want. Even if they are never ever going to actually use it. Sometimes those programs properly deallocate memory, sometimes they don’t. Sometimes, programs leave parts of themselves in allocated memory just in case you are going to run that program again. If you have no page file and a program wants to commit some for itself, your PC will crash.
Paging file configuration is in the System properties, which you can get to by typing “sysdm.cpl” into the Run dialog, clicking on the Advanced tab, clicking on the Performance Options button, clicking on the Advanced tab (this is really advanced), and then clicking on the Change button. I would suggest a value of 1.5X the currently allocated value. Windows supports up to 16 paging files, where each must be on a separate volume, so if you have more than one internal disk drive you could also try enabling a Paging File on your second hard-disk.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Nigel O’neill
November 7, 2010 at 3:17 amKen
If you have Vegas x64 you should be able to render out the file. I got the low memory error all the time in Vegas 9.x and my “workaround” was to render in Vegas x64.
Intel i920, 12GB RAM, ASUS P6T, Vegas Pro 9 (X64), Vista x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S 4.1
