Activity Forums VEGAS Pro vegas video to dvd problems
  • vegas video to dvd problems
    Posted by Michael O’connor on September 28, 2006 at 6:56 pm
    Not sure where to start for help so here goes…I have a project in vegas that I need to go to dvd. I have vegas 4 and dvd archetect 1.0 I haven’t done any work with dvd’s, only cd’s and going to tape…I think I read once that when you make a dvd in arch you shouldnt try to burn it to dvd using arch, but rather use something else like nero to burn to dvd? I have tried in arch and it says it prepared, then I go to burn and it says inproper media for drive. I have dvd-rw selected on burner, and the media is dvd-r . The same happens with nero if I select dvd-video files. If I try to burn with nero with data burn, it warns me about a 2 session burn and the 2nd session may not be read…then it trys to burn, and stops with error message. If I open the message it is about three pages long. Does this sound like a burner problem? It works fine with cd’s. Or am I doing something wrong in architech or nero or both? Frustrating. Thanks for any help.
    Terje A. bergesen replied 19 years, 11 months ago 4 Members · 5 Replies
  • Adam Rose esq.
    September 28, 2006 at 7:14 pm
    well, FWIW, I never burn with anything other than architect, UNLESS i need to add extra data files. Architect has always come up trumps for me. until this month, was using V5 and A2
  • Terje A. bergesen
    September 29, 2006 at 5:34 am
    If you can get some more of the Nero error messages (verbatime) that would help. It may be your burner is a little old, or it may be that your media is bad.
    Terje A. Bergesen
  • Michael O’connor
    September 29, 2006 at 2:47 pm
    Thanks for the help. As it turns out it was the media. I was using dvd – r and after using dvd + r to record to it worked fine! I have made copies before onto the dvd – before and never had a problem. I guess you can copy to them, but not burn to them? Anyway problem solved and I appreciate your input. Have a great weekend. Michael
  • Allen Zagel
    October 1, 2006 at 1:35 pm
    Oh no! You may have something else wrong. I burn DVD-/+ R’s all the time directly from DVDA-2 and never had any problems. EXCEPT!! when I was using a Sony burner, (DRU-500A and DRU-540). Put them both in the garbage, went and got a Mad Dog (worked fine) then when I bought my new editing machine it came with HP Light scribe burner. Needless to say I’m sour on Sony stuff! 😉 ….and I don’t use RW’s.I’ve found they’re not reliable in my case.
    I wonder if you don’t have a burner problem.
    And I never use Nero. Had too many problems with them a few years ago. If I create it in Vegas5/DVDA-2, I burn it from DVDA-2. But I also use DVD Lab Pro and that came with a beautiful burning software Copy-to-DVD. Other than that my software of choice is NTI.
    Until I got my Disk Maker’s 4-up duplicator at NAB last April I’d just go to DVDA, and use that to make my dupes.
    Allen
    ASX Media Productions
    https://www.asxvideo.com
  • Terje A. bergesen
    October 2, 2006 at 3:39 am
    It rarely is a +/- issue, it is more the quality of the media. There is a lot of garbage out there, and when you buy garbage media you will produce more coasters than you wish.
    Terje A. Bergesen
