Activity Forums VEGAS Pro Vegas v.7 or Connect HD?
  • Vegas v.7 or Connect HD?
    Posted by Lee Mceachern on August 26, 2006 at 12:03 am
    For those of you who:
    1. Have seen the specs Sony has revealed for Vegas v.7, and
    2. Have experience working with Connect HD,
    …perhaps you can provide some insight for me. I have some HDV work coming up in a month or so (to be shot on a Sony HDV camera) and I have been planning to get Connect HD to work with my Vegas 6. However, the release of the new version of Vegas is scheduled for September and I’m wondering if it will do what Connect HD does. I don’t want to spend the money for Connect HD and have it become obsolete as soon as I buy Vegas 7. I’ve never edited HDV material before and I want to get my system ready for this job.
    Thanks for your thoughts…
    Lee
    Jerry Waters replied 20 years ago 5 Members · 7 Replies
  • 7 Replies
  • Sada
    August 26, 2006 at 2:05 am
    I suspect that 7 will merely allow you to handle your files the way that Connect HD does—in fact the module might be licensed from Connect HD.
  • Robroy
    August 26, 2006 at 2:29 am
    Vegas 6 already includes Connect HD.
  • Peter Wright
    August 26, 2006 at 8:24 am
    The Cineform codec you buy with Connect HD is meant to be slightly better and faster than the one included with V6.
    Whether this difference will remain with V7 remains to be seen, plus whether Vegas t Internal Capture will do Scene Detection for HDV, which Connect HD does but V6 does not.
    There is also the issue of how relevant Intermediates or Proxies will still be, particularly if, like me, you have a 4 year old PC
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Lee Mceachern
    August 26, 2006 at 3:46 pm
    Thanks all for your comments. I appreciate the education. Peter, your reference to “Intermediates or Proxies” illustrates how little I know about editing HDV. Does that refer to the delta frames that occur with GOPs (which, as I understand, are part of the HDV compression)? Do you have a reference location, article, etc. where I can get better informed before I take on this HDV project?
    Thanks for any advice.
  • Peter Wright
    August 26, 2006 at 11:43 pm
    Because HDV and its compression makes it hard to edit with on anything but a superfast PC (so far …..) the solution has been either:
    Intermediates: This is a misleading name, because Intermediates such as Cineform’s are .avis at full HD resolution, and in fact they take up 3 times as much space. They are created as a render from the original HDV footage, and can be used for easy smooth editing, right through to the final render.
    Proxies: Best done with a plug-in like Gearshift, these care widescreen DV avi files which “temporarily” replace the HDV files on the time line. They take up about the same space as HDV. They are also rendered from the HDV files and are quick and easy to edit with. Once the edit is done, a single click in Gearshift replaces the proxy files with the original HDV .m2t files ready for final rendering and output.
    Peter Wright
    Perth, Western Oz
  • Lee Mceachern
    August 29, 2006 at 1:26 am
    Thanks Peter. I’ll stick my toe into this deep water and see how it goes…
    Cheers,
    Lee
  • Jerry Waters
    August 31, 2006 at 4:17 am
    Not really. Vegas 6 has Cineform (by license) but not Connect HD. They capture differently, Connect has a more advanced codec and scene detection.
    JerryW
