Activity Forums VEGAS Pro Vegas Unusable Problem – Audio Peaks GONE
  • Vegas Unusable Problem – Audio Peaks GONE
    Posted by Russell Gough on December 22, 2010 at 12:53 am
    using Vegas 32 & 64 bit on Windows 7 PC. Everything fine except last week I finished making a music video. Saved it in 3 locations with complete/trimmed source files. One week later all of these files cause vegas to crash while loading at same percentage…if I hadn’t already rendered out a “high quality” MP4 for youtube this would be a big disaster..as it is Im rendering from a render as original is NOT USABLE….
    Now..EVEN WORSE….I start on new music video and load 5 wav files in of drums/bass/guitar etc cos I want to tidy them up….NO PEAKS!! Doesnt even attempt to build them. NO option in Prefs/Gen to turn them on or off? I have NOT changed a thing in vegas prefs or on my PC.
    Shift F5/Rebuild peaks does nothing at all..not even an error message. I have uninstalled and re-installed and rebooted.
    My work is making music videos and recording/mastering mixing…I CANT WORK please help ASAP I am supposed to get a mix to the band tonight and Vegas is broken..
    Russ
    youtube.com/user/sloppysmusic
    at the above link is the video that I can not open again…at least there is a restore.veg I can go back to but this will result in a different final version…
    Russell Gough
    Daytona Cameras Inc.
    http://www.daytonacameras.com
    Russell Gough replied 15 years, 9 months ago 2 Members · 4 Replies
  • John Rofrano
    December 22, 2010 at 1:14 am
    [Russell Gough] “NO option in Prefs/Gen to turn them on or off?”
    Try: View | Audio Event Waveforms (Ctrl+Shift+W)
    [Russell Gough] ” I have NOT changed a thing in vegas prefs or on my PC.”
    I’d bet you typed Ctrl+Shift+W without realize it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Russell Gough
    December 22, 2010 at 1:29 am
    Thanks John!
    I must have done….although I was confused how both 32bit and 64bit versions were affected…I guess the hardware addressing portion of Vegas is different between versions but the user interface is the same.
    Once again thanks especially for the fast reply! I can work again 🙂
    Oh…wow again. I can open that video project again…weird as it was only that one project affected…
    Phew…sorry all for my panic!
    Russ Gough
    Russell Gough
  • John Rofrano
    December 22, 2010 at 2:56 am
    Glad that’s all it was. Vegas 32-bit and 64-bit share all the same parameters. Think of them as just one program that can run in either 32-bit mode or 64-bit mode because that’s how it behaves.
    ~jr
  • Russell Gough
    December 22, 2010 at 4:01 am
    I learn something new every day! I may just stick with 32 bit
    as Magic Bullet Looks wont work with 64 bit anyway. Lifesaver tonight..daily audio demo complete 🙂
    Thx
    Russ
    Russell Gough
