Activity Forums VEGAS Pro VEGAS Unmanaged Exception (0xc0000005) ONLY IN ONE EDIT LIST
  • VEGAS Unmanaged Exception (0xc0000005) ONLY IN ONE EDIT LIST
    Posted by Mario Gonzalez on December 25, 2013 at 8:39 pm
    Happy Holidays to everyone:
    Not too much for me since i been waiting for a while to get this time to edit my daughters dance video after a lot of productions for other people, but guess what? her edit list after a few hours of work wont open anymore, I get this error and tried several fixes including uninstalling quicklime, deleting preferences, etc an prior edit list from the same projects opens fine, it has the same files, nothing new and has almost no effects yet.
    I really will appreciate and advice on this issue.
    Extra Information
    File: C:UsersusuarioAppDataLocalSonyVegas Pro12.0dx_video_grovel_x64.log
    File: C:UsersusuarioAppDataLocalSonyVegas Pro12.0svfx_video_grovel_x64.log
    File: C:UsersusuarioAppDataLocalSonyVegas Pro12.0ocio_x64.log
    File: C:UsersusuarioAppDataLocalSonyVegas Pro12.0dx_grovel_x64.log
    File: C:UsersusuarioAppDataLocalSonyVegas Pro12.0gpu_video_x64.log
    File: G:Onixeus 2DATA3.Hi guys,
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 12.0 (Build 770) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Program FilesSonyVegas Pro 12.0vegas120.exe
    Fault Address: 0x000007F78412FE25
    Fault Offset: 0x000000000018FE25
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 12.0vegas120.exe
    Process Version: Version 12.0 (Build 770) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2013-11-21 (Thu Nov 21) 00:45:00
    John Bolton replied 12 years, 8 months ago 2 Members · 3 Replies
  • John Bolton
    December 26, 2013 at 8:41 am
    This worked in VP11…
    Do a Vegas “reset to default values”
    Close the program. Now press CTRL+SHIFT while double-clicking on the program’s icon to launch it. Continue to hold the CTRL & SHIFT keys until the program is fully up and loaded.
    In newer programs, you will see a window that asks “Do you want to reset all preferences to default values?” Place a checkmark next to “Delete all cached application data” and then click Yes.”
    Also have you tried disabling the GPU accelerator in Options/ Preferences…
  • Mario Gonzalez
    December 26, 2013 at 5:03 pm
    Good Mornig , thank you very much, it works, now I can open the edit list with no problem, I still have GPU aceleration on with no problem also on a Nvidia Galaxy card GeoFoprge GT 640 and use CODA to render
  • John Bolton
    December 27, 2013 at 8:41 am
    That’s great. Glad you can continue to work again. Regards John
