Activity Forums VEGAS Pro Vegas to DVD Architect Slide Show Question
  • Vegas to DVD Architect Slide Show Question
    Posted by Chris Borjis on July 1, 2005 at 11:32 pm
    When encoding stills from a Vegas timeline into DVD Architect
    does the mpeg2 encoder encode the stills as single I-Frames
    or as an mpeg2 video stream?
    Reason I ask is, some authoring programs do convert
    stills to I-Frames resulting in amazing capacities.
    one frame might be 600k but look pristine, but if it
    were video it would take up a bunch more room just like
    video.
    I have a vendor who may well need this capability but I’d
    rather do it from vegas because its so much easier and I don’t
    have to deal with maintaining proper viewing ratio’s with
    different sized graphics.
    Strobealific replied 21 years, 2 months ago 3 Members · 2 Replies
  • Edward Troxel
    July 1, 2005 at 11:44 pm
    If you encode to MPEG2 from Vegas, you will get an MPEG2 stream. I’ve not heard of anything that does what you are saying.
    Edward Troxel
    JETDV Scripts
  • Strobealific
    July 3, 2005 at 8:28 pm
    If you just want stills with music, you should just use the “slide show” default in DVD-A.
    You won’t be able to do transitions, but it will save you a lot of render time. It depends on your need.
    Marc Bowyer
    StrobeAlific Media
