Activity Forums VEGAS Pro vegas time line loop
  • vegas time line loop
    Posted by Gary & yvonne on June 8, 2005 at 7:51 am
    I’m trying to render a clip and it will only render 1 second. Because above the time line there’s a blue arrow with a line that has to do with a loop because i can drag in open to select more of the clip….My question is how do i get rid of the blue arrow so i can render the whole clip? Thanks for you help.
    Gary & yvonne replied 21 years, 2 months ago 3 Members · 5 Replies
  • Mike Kujbida
    June 8, 2005 at 10:56 am
    When you select the “Render As” option, is the “Render loop region only” disabled?
    Mike
  • Gary & yvonne
    June 8, 2005 at 3:28 pm
    Mike thanks, Thats my problem The RENDER LOOPED REGION ONLY is checked and greyed out….where do i find to uncheck this? Thanks
  • Gary & yvonne
    June 8, 2005 at 3:57 pm
    I will also add to my question….I’m rendering in 3 parts to my project,using video for windows (avi), NTSC DV for the template and audio 48,000Hz, 16 Bit,Stero PCM uncompressed. with the only checked boxes Render loop region only (which I want to know how to remove) and Save project markers in media file…
    After my whole project is completed i will connect the 3 parts together and Render as MPEG 2 without audio and then render again with ac3 audio…My question is this process the correct way of going about connecting clips together? Also how do i uncheck the greyed out RENDER LOOP REGION ONLY……..Thanks so much…..
  • Edward Troxel
    June 8, 2005 at 4:43 pm
    If that box is grayed out then you don’t have a loop region specified. Make a loop region on the timeline and that box will be available. Since you don’t have a loop region, that can’t be the problem. Can you tell us more?
    Edward Troxel
    JETDV Scripts
  • Gary & yvonne
    June 9, 2005 at 4:27 am
    Edward, what i ended up deciding to try was loop the whole clip to render, and when i went to choose to render it the RENDER LOOP ONLY came out of being greyed out so i was able to then uncheck it. thanks for you reply………Gary
