vegas time freeze?
Posted by Franco2 on September 6, 2007 at 10:29 amCan sony vegas 7 make time freeze as in adobe after effects?. Unfortonately, I can’t find the time remapping in vegas just like in Adobe AE. Please help me. thanks.
Mark Pi replied 19 years ago 4 Members · 4 Replies -
Mike Kujbida
September 6, 2007 at 12:00 pmInsert a Velocity envelope on the track, add points and set the speed (-100% to +300%) as desired.
Edward Troxel
September 6, 2007 at 12:13 pm -
Mike Kujbida
September 6, 2007 at 12:27 pm[jeditdv] “The Velocity Envelope is EVENT level.”
Thanks for catching that Edward.
I’ve been doing a lot of velocity envelopes the past few days so you’d think I’d know better 🙂 -
Mark Pi
September 6, 2007 at 1:47 pmYou can also:
1. SPLIT where you want the freeze,
2. Move the right part to where you want the freeze to end.
3. Then move back a frame and SPLIT again to single out a frame,
4. Then right-click on the single frame and click CREATE SUBCLIP.
5. Finally, grab the right edge of the single frame and stretch for the duration of the freeze.
I just did a project with a lot of freezes, and this was fast and simple (just three keystrokes, a slide, a right-click, and another slide), and easy to edit afterwards.
