Activity Forums VEGAS Pro vegas settings for GoPro
  • vegas settings for GoPro
    Posted by James Fox on November 11, 2011 at 12:00 pm
    Hei,
    sorry to ask such thing, but I am a bit troubled while choosing my project and rendering settings for camera I havent used before.
    Camera: GoPro HD
    heres source video:
    Format : MPEG-4
    Format profile : JVT
    Codec ID : avc1
    File size : 865 MiB
    Duration : 7mn 59s
    Overall bit rate : 15.1 Mbps
    Encoded date : UTC 2011-08-11 17:11:31
    Tagged date : UTC 2011-08-11 17:11:31
    AMBA :
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 7mn 59s
    Bit rate mode : Constant
    Bit rate : 15.0 Mbps
    Nominal bit rate : 18.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.289
    Stream size : 857 MiB (99%)
    Title : GoPro AVC
    Language : English
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format version : Version 4
    Format profile : LC
    Codec ID : 40
    Duration : 7mn 59s
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 7.31 MiB (1%)
    Title : GoPro AAC
    Language : English
    AND Photo
    Format : JPEG
    Width : 2 592 pixels
    Height : 1 944 pixels
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    HERE IS OUTPUT FROM VEGAS:
    General
    Complete name : C:UsersKaupoDesktop2.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 15.8 MiB
    Duration : 8s 680ms
    Overall bit rate : 15.2 Mbps
    Encoded date : UTC 2011-11-11 11:48:54
    Tagged date : UTC 2011-11-11 11:48:54
    Video
    Format : AVC
    Format settings, ReFrames : 3 frames
    Codec ID : avc1
    Duration : 8s 680ms
    Bit rate : 15.1 Mbps
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.291
    Stream size : 15.6 MiB (99%)
    Language : English
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 8s 661ms
    Bit rate : 128 Kbps
    Stream size : 135 KiB (1%)
    Language : English
    I see there are still some diferences (highlighted in bold)
    Should I change something, I did all I could to match the input and output settings, but I dont understand all these terms and stuff very well. My output is for watching in pc,youtube or tv, just for own and friends.
    In rendering settings there is “number of reference frames” which I put on 4, in output I think its 3, if this is the same thing at all, sry.
    And one thing I did not know that to do, USE DEBLOCKING FILTER? At moment it is not selected.
    Under Project Settings there is deinterlacing method: Blend fields (selected). Should I change this?
    John Rofrano replied 14 years, 10 months ago 2 Members · 3 Replies
  • John Rofrano
    November 12, 2011 at 2:53 am
    You project settings should match your source which is 1920×1080 HD. You render settings should match whatever delivery format you are using. You should not expect to render back to your cameras format. Those days are long gone because cameras these days use formats that are optimized for capture and not necessarily playback/delivery.
    If you want to render to AVC use the Sony AVC or MainConcept AVC formats with one of the Internet templates.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • James Fox
    November 12, 2011 at 7:56 pm
    Okey, thanks for your reply. What do you reccomended instead of AVC for HD video?
    I actually have a bit problems while editing, too choppy preview. Im thinking of rendering the source to some less compressed format before editing, what would you reccomended for that?
  • John Rofrano
    November 13, 2011 at 2:51 pm
    [James Fox] “I actually have a bit problems while editing, too choppy preview. Im thinking of rendering the source to some less compressed format before editing, what would you reccomended for that?”
    I would recommend either HDV or XDCAM. HDV MPEG2 should be the easiest HD format to edit. Even an old Dual Core PC should be able to handle it without any problems.
    ~jr
