Activity Forums VEGAS Pro Vegas renders into multiple files…
  • Vegas renders into multiple files…
    Posted by Fernando Park on August 13, 2010 at 12:14 pm
    Hi fellas,
    I’m a beginner when it comes to using this software so please bear with me.
    I’m trying to render my project (about 32 minutes long) into a single .avi file. When attempting to do so, after about 6-8 hours, I look at the finished product and I see about 40+ files of the same length (about a minute) and file size (about 3GB)! And none of them work. Am I doing something wrong here? It’s frustrating because it takes so long to render the damn project. I’ve rendered a smaller project before of about 8 minutes and I had no problems.
    Please help.
    Fernando Park replied 16 years, 1 month ago 2 Members · 2 Replies
  • John Rofrano
    August 13, 2010 at 5:46 pm
    It sounds like the drive you are rendering to is using the FAT32 file system which has a 4GB file size limit. If so, you should find the answer to your problem in this thread:
    Files after rendering
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Fernando Park
    August 13, 2010 at 6:48 pm
    John, you are probably correct. I did format my portable hard drive so that my PS3 can read it. I’ll try this out and let you know.
    Thanks a lot
