Activity › Forums › VEGAS Pro › Vegas renders darker than appears in preview.
  • Vegas renders darker than appears in preview.
    Posted by Paul Hildebrandt on September 22, 2008 at 3:42 pm
    I am having a problem with Vegas that whenever i render my project it appears darker than it should. But looks how i want in the vegas preview window pre-render.
    The video files being used are NTSC DV, project type is set correctly to match those settings, and i am rendering back out to NTSC DV, if i print the image to tape it is also darker on TV but i expect this due to difference in monitors. But i figure it should be same on the computer between the preview window and the final project.
    Would appreciate any help. Thank you.
    Linda O’connell replied 17 years, 6 months ago 5 Members · 6 Replies
  • Terry Esslinger
    September 22, 2008 at 9:38 pm
    What video player are you using to play back the rendered video. If you drop it into a Vegas project and preview it does it still appear darker?
  • Paul Hildebrandt
    September 22, 2008 at 10:16 pm
    Using windows media player, default color settings. I have not tested putting it back into Vegas, i’ll have to try that when i get home. But for example if i import the rendered file into photoshop for rotoscoping, it looks very dark as well, as it does in windows media player.
  • Paul Hildebrandt
    September 23, 2008 at 3:38 pm
    Alright i tested the issue and when i re-import back into Vegas it does not look dark. But it does look darker in media player, and even darker in photoshop.
  • Jeff Bellantine
    October 7, 2008 at 3:33 pm
    I am having the same problem. I’ve never had an issue with the darkness before but the project I am working on now is rendering the same way. I have two projects (1) is 1440 1080 24p and (2)1440 1080 30p. They both come out in WMP about one click low on the brighness. I am running a Dell Ultra Sharp 24″ at home when previewing in Vegas.
    Anyone else other than us having this problem?
    Thanks.
  • David Killingsworth
    November 11, 2008 at 4:54 pm
    I’m having the exact same problem as well. I’d like to find a solution for this soon! I didn’t seem to have the problem when I was using Sony Vegas 8, but unfortunately I had to go back to using Vegas 7 since version 8 wasn’t compatible with the video format my new camera uses.
  • Linda O’connell
    March 26, 2009 at 1:28 pm
    I am also having this problem. Did anyone find a solution yet?
