Vegas & Rampant Does Go Together
Posted by Ken Bennett on September 3, 2013 at 3:45 amI’ve come to the conclusion that Rampant filters do not work with Vegas Pro 12. Whenever I use them, Vegas will crash 100% of the time within 3-8 mins. Even just reviewing them in Vegas before they get to the timeline Vegas will crash.
Am I the only one who has discovered this?
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures!Ken Bennett replied 13 years ago 2 Members · 6 Replies -
Steve Rhoden
September 3, 2013 at 3:57 amRampant Filters?
What exactly are you speaking of?If you are referring to the varied composited Video files
that make up the various products being offered at Rampant Designs,
They are not called filters and they work fine for me, they
are just video files you composite on top of your regular
footage etc.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019 -
Ken Bennett
September 3, 2013 at 4:50 amYeah, I guess they really are just videos. But whenever they get into Vegas, Vegas doesn’t like them and will start to crash. I’ve had no problem with other video overlays from Digital Juice. There just seems to be something Vegas doesn’t like. At least on my system. When I edit with these I have to save after every single step I make as I edit because I know it will crash within a few minutes. Today alone I’ve sent Sony 8 crash reports all within one hour.
I know Vegas doesn’t like something on my so-called high-end PC due to the daily crashes on all projects. I will swap out my Q4000 card for a lower GeForce card and see if that’s the issue. Someone said it might be a memory issue. I’ve got 32GB of memory. I do still have about 60 things running in the background that I have no idea what they are or need to be running. These are all at startup. Too bad nobody can just go on my system and look around and see what the problem might be.
Sony’s only suggestion is to uninstall, create a new user account. Install on the new account and not install any 3rd party plug-ins. So if that works I start loading in my NewBlue stuff. I require a lot of 3rd party stuff to produce my projects.
Ken Bennett
Video Adventures
Capturing Your Life’s Adventures! -
Steve Rhoden
September 3, 2013 at 6:18 pmSo hard to tell you exactly what your problem might be Ken.
I very much doubt changing the card is gonna yield any difference.
I would think you would have had an issue with Digital Juice
files instead, because their files are always so large.Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Ken Bennett
September 4, 2013 at 5:32 pmI’ve used Digital Juice stuff for years. I think almost all the files I bring in are a MOV file. I use After Effects for any of their templates and those and rendered out to MOV files. Rampant file are also all MOV files. If I’m having less crashing issues when editing without these “effects”, it seems that maybe the way I have my Vegas setup and/or the way my PC is setup, MOV files are affecting something.
Ken Bennett
Video Adventures
Steve Rhoden
September 5, 2013 at 2:39 ammmmmm, is it the latest version of Quicktime you have installed?
Just covering all the possibilities!Steve Rhoden
(Cow Leader)
1-876-461-9019 -
Ken Bennett
September 5, 2013 at 3:35 amVersion 7.7.4
Ken Bennett
Video Adventures
