Activity Forums VEGAS Pro Vegas Pro wont complete render
  • Steve Rhoden
    November 25, 2012 at 11:03 pm
    Good to hear, although that solution is not too comforting.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Martin Donison
    January 5, 2013 at 9:56 pm
    Hey there
    I have had the same problem as you come up awhile ago and it has frustrated me to no end this last two months! I had no trouble before, it would render everything fine, and now it does exactly as you described, renders to a point then whole thing freezes and the count down just ends. Only way to get out of it is task manager kill it. Vegas 11 has been coughing up different problems constantly, first it doesn’t even recognize .MOV files at all, now this. So I went ahead and tried Vegas 12 and guess what? It does the same thing!! Hangs at the first few seconds of rendering! I just don’t get it…spend hours and hours reading forums and everyone says something different, I try all the suggestions, and nothing works…really makes me lose interest in editing and I get no work done!
  • Aidan Frampton
    March 2, 2013 at 1:33 pm
    I also had this issue. Turning off the GPU Accelerated Render in the preferences seemed to fix it for me :p
  • Peter Staab
    April 26, 2013 at 6:07 am
    I had the same problem with Sony Vegas 12 for months. Sometimes rendering worked fine, then it stopped somewhere in the middle.
    But I think I found a solution:
    Method 1 (as mentioned above):
    – Go to “Options” – “Preferences” and disable GPU acceleration
    Method 2 (if you have multiple graphic cards, such as the Intel on the mainboard and an external Nvidia/Amd one):
    – Go to “Options” – “Preferences” and select the external graphics card (the internal Intel HD4000 seems to cause the problems on my device), click “Apply” and restart Sony Vegas
    IMPORTANT: to change settings start Vegas as administrator (right click on the Sony Vegas icon -> “Run as administrator”). Without doing this, both methods did not work for me. After changing the settings you can start Vegas normally again.
  • Thayalan Paramasawam
    April 26, 2013 at 4:08 pm
    Thats good…….at last found the solution
  • Davy Force
    October 18, 2013 at 8:55 pm
    HI THERE
    After having this issue as well- and trying EVRYTHING listed here- still had the same issue-
    Finally zeroed in on the culprit-
    an audio Sony Pitch filter set to high quality Speech 7 mode locked up the render every time. When using lower settings got it to render. So its not just bunk GPU and memory cache settings in some cases but buggy audio issues as well.
    ARGGG SONY!!
Page 2 of 2
