Activity Forums VEGAS Pro Vegas Pro -Video completely looses focus after being added to the timeline
  • Vegas Pro -Video completely looses focus after being added to the timeline
    Posted by Monica-Ioana Diac on August 25, 2020 at 3:11 pm
    Hello.
    I have this never before encountered problem that i don’t know how to fix.
    So: I start a new project and just add the video i need. Immediately the preview window (which is set to Best (full)) goes extremely out of focus.
    I rendered a tiny bit to see if it affects the output and it does, it is as blurry as the preview.
    I made a short movie a while ago using videos filmed with my phone. Everything was great and worked as it should. But now, using the clips filmed with the same phone make my eyes tear up. I didn’t fiddle with the default settings then and I didn’t now.
    What is going on??? How do I fix this?
    Monica-Ioana Diac replied 6 years ago 4 Members · 5 Replies
  • Graham Bernard
    August 26, 2020 at 5:56 am
    [Monica-Ioana Diac] “What is going on??? “
    Yeah, I agree! What is going on. Need more information. Just for starters, your Settings, the full info on your media, had you used any FXing.?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Monica-Ioana Diac
    August 26, 2020 at 2:03 pm
    Thank you for responding
    If by settings you mean the Vegas settings I use at the start of any new project, here there are
    And the media info
    And no. Brand new project. Didn’t use FX
  • Wayne Waag
    August 28, 2020 at 5:37 am
    I think I see your problem. In your project settings, your field order is set to UpperFieldFirst which is interlaced. Since your footage is apparently cell phone video, it is progressive.
    To correct, change field order to Progressive. Also click on your media file properties and make sure that the field order is also set to progressive.
    wwaag
  • Francois Pénzes
    August 28, 2020 at 2:14 pm
    Hi Monica
    Looking at your screen capture, I see that you got your V17 on GETGAMEZ. Now, I’m not saying that you got a cracked version but for all others out there, a lot of the problems that you will experience with VEGAS will be directly related to a non-legit version. Not to mention the possibility of having your drive(s) corrupted.
    Just sayin’
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Monica-Ioana Diac
    September 1, 2020 at 5:37 am
    right
    Anyways, I reinstalled it and now it works.
