Vegas Pro: replace a selection from the timeline
Posted by Kurt Van impe on March 25, 2008 at 10:29 amHi,
In Vegas Pro 8.0: I want to replace of selected piece of the timeline (a selection of video and audio tracks) en replace it on the end of the timeline. Is it possible to do that en how can I do that please?
Many thanks!
Don Bloom replied 18 years, 6 months ago 3 Members · 5 Replies -
Don Bloom
March 25, 2008 at 12:03 pmsure you can. What I do (and I know there are probably 17 other ways to do it 😉 ) is to highlight the clip I want to move to the end, CONTROL X, then hit the F key to ripple the rest of the clips to the LEFT-I then go to the end of the timeline and click on it then hit CONTROL V to paste the clip in there. Works the same no matter where you want to place it.
Don -
Kurt Van impe
March 25, 2008 at 1:28 pmThank Don. I gave it a try but I work frequently with ‘locks’ and this way of work gives me too much problems. Are there any other options to do what I want?
Many thanks!
Terry Esslinger
March 25, 2008 at 4:53 pmI’m not sure what ‘locks’ is but you could probably (S) Split the section of video that you want to move and drag it to the end. You then would have to manually close the gaps unless you have rippple engaged (which I usually don’t)
Kurt Van impe
March 25, 2008 at 10:53 pmWith ‘locks’ I mean: proproties; switches; lock. I use this when I want to switch the video track without losing the audio track of that video track. Your suggestion is good but I can’t use it because I can’t split the clip: there are 3 seconds “pause”: there are no video tracks to split…
Don Bloom
March 26, 2008 at 2:13 amI’m sorry but I’m really confused.
I do projects all the time with multiple video tracks (up to 10 or 12) and use 1 audio track and move clips around all the time so I’m not quite sure I understand what you mean.
Could you please clarify a bit?Don
