Activity Forums VEGAS Pro Vegas Pro render freezes at certain points.
  • Vegas Pro render freezes at certain points.
    Posted by Rohan Mehta on February 1, 2020 at 10:04 am
    I encountered this problem yesterday afternoon and have not been able to fix it.
    In the preview box, the video plays smoothly throughout the video; however, when I render it, the video freezes at certain points in the video.
    I have tried two different rendering formats (MAGIX HEVC/AAC MP4 and MAGIX AVC/AAC MP4) and the same problem occured.
    Here is a small snippet of the video (Yes, it is Fortnite): https://drive.google.com/open?id=1FrufUsOwiRJyp4U8ZPajqMFf5sNP-Ngh
    Rohan
    Rohan Mehta replied 6 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Graham Bernard
    February 1, 2020 at 2:07 pm
    What’s your question?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Rohan Mehta
    February 1, 2020 at 4:27 pm
    The video render freezes at random points in the video; however in the preview this does not happen.
  • Graham Bernard
    February 1, 2020 at 5:47 pm
    Sounds like your setup can’t cope with the render.
    * Grazie
  • Rohan Mehta
    February 1, 2020 at 9:07 pm
    I have a Ryzen 2700x and a 1050Ti, upgrading to 2060 S soon.
    Thank you for your help – I will just await the arrival of the new GPU.
  • Omer Aydin
    February 1, 2020 at 10:14 pm
    Maybe the problem is caused by your source video. It’s easy to test it;
    Just try rendering your project in a lower resolution like 480p , using 2 different codecs, then test the playback of your output files, see if they still stutter…
    If they do then it’s your system –> Upgrade.
    If they don’t then your source video file is corrupt or it’s codec has issues with Vegas. –> Transcode into a new video file and use them instead of the original files.
  • Graham Bernard
    February 2, 2020 at 3:18 am
    I agree that it is one or even BOTH of the issues you are inviting our Friend here to explore, “Media/Settings” and then “System”. In any event we require far more information to analyse which can only come from the OP.
    Let’s see ????
    * Grazie
  • Rohan Mehta
    February 12, 2020 at 9:46 pm
    Thank you for your time!
