Activity Forums VEGAS Pro Vegas Pro Production Assistant 2 Batch processing .veg files
  • Vegas Pro Production Assistant 2 Batch processing .veg files
    Posted by Areal Nayme on August 18, 2016 at 11:03 pm
    Just got Vegas Pro Production Assistant 2 and think maybe I misunderstood some advice someone gave me to buy this. I want it to batch render a folder of completed videos that now sit in the form of Sony Vegas 13 .veg files. Instead of me pushing render every hour or so to do so myself, it, I was told, would just process one after another. But, I’m not seeing how it does this….
    How does it do this?
    John Rofrano replied 10 years, 1 month ago 2 Members · 1 Reply
  • John Rofrano
    August 19, 2016 at 9:40 pm
    [Areal Nayme] “I was told, would just process one after another. But, I’m not seeing how it does this….”
    1. On the Source Media tab, Add all of your veg files to the list
    2. On the Processing tab, Select (none) as the preset and set Options to: Process each file individually. It’s important that you set this correctly or else it will not process each file in succession.
    3. On the Target Outout tab, Select your Output location and Output formats
    4. Press Process
    Production Assistant will process each veg file individually by rendering to all of the output formats you selected.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
