Activity Forums VEGAS Pro Vegas Pro Preview Not Working (Repost)
  • Vegas Pro Preview Not Working (Repost)
    Posted by Jreyden Bangloy on February 9, 2019 at 6:48 pm
    I posted this issue before but the post is gone so I’ll just explain the issue again. My preview screen does not work and is stuck on one frame. If you change the size of it (either shrinking or stretching) the preview will update on the frame that the video is on at that specific moment of time. For the Dynamic RAM preview, the maximum available is 15236 MB. GPU acceleration is on and my GPU is a NIVIDIA GeForce GTX 960M. My CPU is an i7-6700HQ CPU 2.60 GHz. My ram Is 16.0 GB and my operating system is Windows 10 64-bit. This issue occurs on Vegas 13, 14, and 15 for me. The preview screen used to work until I went to Vegas 15. Once I did that, the preview screen stopped working for all three. Thank you for reading this post. Cheers!
    Jreyden Bangloy replied 7 years, 7 months ago 3 Members · 3 Replies
  • Paul Berk
    February 9, 2019 at 7:18 pm
    Reboot your system. Open Vegas 15. Do View/Windows Layout/Default Layout. Is the Preview screen there?
    If so, put some media on the timeline. Still ok?
  • George Dean
    February 9, 2019 at 7:36 pm
    Jreyden,
    Your previous thread is still listed here, I do not know why you cannot see it.
    I would do a full reset and test. Does VP15 still not run properly?
    I would turn GPU acceleration ‘Off’, does VP now work properly?
    Have you recently update the GPU driver, or has Windows done an update driver automatically? If so, I would roll back the GPU driver to a previous version, does VP15 work properly now?
    Right click on the preview display and look at ‘Adjust Size and Quality for Optimal Playback’. If it is checked, un-check and does the problem still persist?
    You could do a search for ‘Clean Un-Install of Vegas Pro 15’ and un-install VP15. Does VP13 and 14 now work again? Probably not because I think it is in your system, but worth a try. If VP13 and 14 now work, I would again install VP15 with the latest build. Does 13, 14, and 15 all work properly?
    Best Regards……George
  • Jreyden Bangloy
    February 9, 2019 at 9:30 pm
    Turning GPU acceleration worked, I did not think it would be that simple. Thank you George and everyone else that helped. Cheers!
