Activity Forums VEGAS Pro Vegas Pro Preview freezing
  • Vegas Pro Preview freezing
    Posted by Liam Brooks on January 16, 2017 at 4:05 pm
    basically I am working on a video but my Vegas is been stupid, every time i add a different clip it lags as it switches to it yet when i first load sony vegas and play it from the start its fine…. only after it’s played once it has this problem on the preview screen. Also media manager is OFF
    To understand me more I recorded the problem https://youtu.be/9ZRm0cK9HPw
    any help appreciated
    Liam Brooks replied 9 years, 7 months ago 2 Members · 5 Replies
  • Aaron Star
    January 16, 2017 at 5:55 pm
    You need to provide more info so the community can help you.
    • Specs on your computer, CPU, RAM, GPU…
    • utility being used to capture game footage, and format you are capturing to.
    • “media info” on the captured media.
    • Project settings in Vegas.
    • Desired rendered output / Vegas Render As template
    • Preferences settings in Vegas.
    Seriously this request should be a sticky on the forum to guide people on how to post for help.
  • Liam Brooks
    January 16, 2017 at 7:01 pm
    Specs:
    Windows 10 64bit
    Intel 6600k OC to 4.1ghz
    GPU : GTX 960
    RAM : 4G
    Recorded with OBS at 1080 60FPS to MP4
    Project settings : https://gyazo.com/1c236614e718c5f60fc59afeace85fb3
    Out put settings: https://gyazo.com/db7019830380e9dc2c8d87c134b161a6
    Vegas preferences: https://gyazo.com/19d4e7ad0294d6b209345c5d8abb6403
    Anything else?
  • Aaron Star
    January 16, 2017 at 7:37 pm
    Under OBS -> Settings -> Advanced – is the CFR (constant frame rate) checked?
    Download a copy of “Media Info” and verify the OBS encoded media is being encoded to a constant frame rate of 60 or 59.94 FPS.
    Try the results of using the x264 encoder vs using quicksync or NVENC.
    Try disabling smart resampling for media clips on the timeline.
    Try Xsplit Broadcaster, as OBS fails to encode to a “video standard” Below is a media info output on an xsplit file:
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Baseline@L3.1
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 23s 12ms
    Duration_FirstFrame : -21ms
    Bit rate : 113 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 30.000 fps
    Vegas is a Video editor that likes encoded source material that conforms to video standards in the TV and Film industries. The video standard in your use case would be 1920x1080x59.94P FPS, or 3840x2160x59.94P FPS. A straight 60FPS should work too, but Media Info results similar to 58.465 to 60.366 will cause playback issues in Vegas.
  • Aaron Star
    January 16, 2017 at 7:40 pm
    This is also same problem with some video from smart phones as well.
  • Liam Brooks
    January 16, 2017 at 8:03 pm
    Ok thanks for the reply I will try what you said
