Activity › Forums › VEGAS Pro › Vegas pro multicam – Point to be aware of
  • Vegas pro multicam – Point to be aware of
    Posted by Clive Delves on November 7, 2019 at 10:50 am
    If you do use the multicam editing you will remember reading the warning given when you choose to “create multicamera track” is says.
    ” Some items (such as envelopes, effects, or motion) will be lost during this operation. Continue?” Yes or No
    I have used the multicam edit many times and fortunately never had any ‘loses’ as a result. However, I now see why this message is there. Because it will remove all slow motion effects, all dissolves AND the actual footage used in those effects, [replacing it with the footage from the default video track (whichever that is) using the timecode of what was there originally] from BEFORE the point where you start the multicam edit. I thought that the warning was only relevant to footage from the multicam edit point down the timeline, not retroactively.
    By luck I will usually do the multicam edit first to get the guts of the story sorted, but today was the first time I sorted the intro before.
    Point to be aware of..
    cheers CD (aka doobre)
    Edward Troxel replied 6 years, 10 months ago 3 Members · 2 Replies
  • Nigel O’neill
    November 20, 2019 at 10:28 pm
    Hence why I use Vasst Ultimate S 4.1 Quadcam…which preserves event level FX
    My system specs: Intel i7 7700k 4.20 GHz, GTX1060, 16GB RAM, Gigabye Z170 HD3, Vegas Pro 13 (x64), Windows 10 x64 Pro, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, VASST Infiniticam 1.7, Neat Video Pro 2.6
  • Edward Troxel
    November 25, 2019 at 7:23 pm
    As does Excalibur.
    Edward Troxel
