Activity › Forums › VEGAS Pro › Vegas pro freezing on certain frame
  • Vegas pro freezing on certain frame
    Posted by Julian Renard on January 9, 2020 at 4:51 am
    Hi! I’m using Vegas pro 16. It worked swimmingly until I got a new gpu(rx470) (don’t have the old one) now when rendering, it freezes on a certain frame each time, it’s different for every project but the frame stays consistent for its respective project. I’ve turned off gpu acceleration, set ram preview to 0, rendered it in a different project, switching the drive, I’ve even gone to the extent of uninstalling the gpu drivers, it worked for one render and never again. Any ideas?
    Graham Bernard replied 6 years, 8 months ago 2 Members · 7 Replies
  • 7 Replies
  • Graham Bernard
    January 9, 2020 at 6:22 am
    [Julian Renard] “Any ideas?”
    Need more information?
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Julian Renard
    January 9, 2020 at 6:48 am
    Sure! Any specific information you’re looking for?
    Specs: fx6300 cpu, rx470 gpu, 8gb ram.
    previous specs which worked: fx6300, gtx950, 8gb ram.
  • Graham Bernard
    January 9, 2020 at 7:27 am
    [Julian Renard] “Any specific information you’re looking for?”
    Rendering and Project Setting Information. The Media you’re using. Without any of this, it’s only half of the detective work required.
    * Grazie
  • Julian Renard
    January 9, 2020 at 7:44 am
    Ah, I see, sorry. I am rendering with magix avc/aac mp4 internet hd1080p 29.97fps all the preferences are default save the ones listed in the original post. I am just using screen recordings from obs, mp4s, which I have never had an issue with before, as well as wavs from audacity for sound.
  • Julian Renard
    January 9, 2020 at 7:50 am
    I should also note the only transitions or effects are fading. and this happens to every project I try to render
  • Graham Bernard
    January 9, 2020 at 7:54 am
    [Julian Renard] “all the preferences are default”
    Please supply a ScreenGrab of your Project Settings.
    Please supply the MediaInfo. To do this I use MediaInfo free utility: >>>located here.<<<
    * Grazie
  • Graham Bernard
    January 9, 2020 at 7:56 am
    [Julian Renard] “I should also note the only transitions or effects are fading.”
    Please read my previous Post. We need to get going with a solution.
    * Grazie
