Activity Forums VEGAS Pro Vegas Pro bug on laptop
  • Vegas Pro bug on laptop
    Posted by Bob Mark on February 20, 2012 at 6:12 pm
    I just installed Vegas Pro 8 on a new laptop running Win 7 64 bit. I installed both the 32 bit and 64 bit versions. I am having a weird bug in both versions. Project setting is 1920 x 1080. I brought in a graphic clip that is 320×240 and selected maintain aspect ratio, but when put on the timeline, the clip is stretched vertically to cover the whole screen. Then after a while of trying to adjust it, the clip becomes unselectable. I can’t even delete it. Any idea what is going on? I have never seen this before. Thanks.
    Bob
    Steve Rhoden replied 14 years, 7 months ago 3 Members · 10 Replies
  • 10 Replies
  • Steve Rhoden
    February 21, 2012 at 8:27 am
    Go to Preferences and under the Editing tab,uncheck
    Automatically crop still images added to timeline.
    Make sure that both versions of Vegas that you have are the
    latest versions.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Bob Mark
    February 21, 2012 at 2:19 pm
    Thanks for your reply. I am on Vegas Pro 8 and there is no option for automatically crop under Options/ Preferences/ Editing. I can’t select the clip on the timeline either. I can’t delete or modify it. Weird.
    Thanks.
    Bob
  • Steve Rhoden
    February 21, 2012 at 8:19 pm
    Maybe its time you upgrade Vegas for a ton of reasons.
    Four versions has seen passed since version 8.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Stephen Mann
    February 22, 2012 at 5:29 am
    [Steve Rhoden] “Maybe its time you upgrade Vegas”
    Especially if you are editing AVCHD.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Bob Mark
    February 22, 2012 at 2:53 pm
    Maybe so. It works fine on my XP box. I don’t use AVCHD.
    Never saw the issue about not being able to select a clip.
    Thanks.
    Bob
  • Stephen Mann
    February 22, 2012 at 3:42 pm
    [Bob Mark] ” I can’t select the clip on the timeline either. I can’t delete or modify it. Weird.”
    This is wrong. If it’s on the timeline you should be able to do anything you want with it – that’s the basic nature of editing.
    By the way – if it’s on the timeline, it’s an event – not a clip. This is important for two reasons. First, on the timeline, an event points to the media (clip). You can have multiple events on the timeline from one clip. You can trim the event, add a bunch of F/X to the clip, and even pan-crop the event. But you never touch the media (clip). This is non-destructive editing. And you can have more events pointing to the same media with each doing something different from the other events. Second, if you search the help file for “how do I do xyz to a clip”, you won’t find anything.
    Steve Mann
    http://www.mmdv.com
  • Bob Mark
    February 22, 2012 at 6:17 pm
    OK. Event. I can’t select it.
    Bob
  • Stephen Mann
    February 22, 2012 at 6:49 pm
    Can’t select, move or edit the event. Sounds like you may have locked it.
    Steve Mann
    http://www.mmdv.com
  • Bob Mark
    February 23, 2012 at 2:31 pm
    Yes. I think you are right. I can’t seem to turn off the stretch. I guess a Vegas 11 upgrade is a good idea. Thank you for the info.
    Bob
  • Steve Rhoden
    February 28, 2012 at 10:58 am
    Anyway you slice it…a Vegas upgrade is a must.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
