Activity › Forums › VEGAS Pro › Vegas Pro 9.0 Error
  • Vegas Pro 9.0 Error
    Posted by Alexandre Almeida on August 28, 2010 at 11:44 am
    since i installed “Maqic Bullets” plugin, Sony Vegas has had some problems. The error happens always after i use the plugin.
    Here is the info about the error:
    Extra Information
    File: C:\Documents and Settings\”””””””\Definições locais\Application Data\Sony\Vegas Pro\9.0\dx_video_grovel_x86.log
    File: C:\Documents and Settings\”””””””\Definições locais\Application Data\Sony\Vegas Pro\9.0\dx_grovel_x86.log
    File: C:\Documents and Settings\”””””””\Definições locais\Application Data\Sony\Vegas Pro\9.0\00000000.restored.veg
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 9.0c (Build 896)
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\WINDOWS\system32\iglicd32.dll
    Fault Address: 0x187D4F4E
    Fault Offset: 0x001B4F4E
    Fault Process Details
    Process Path: C:\Programas\Sony\Vegas Pro 9.0\vegas90.exe
    Process Version: Version 9.0c (Build 896)
    Process Description: Vegas Pro
    Can someone help please?
    Alexandre Almeida replied 16 years ago 2 Members · 2 Replies
  • Stephen Mann
    August 28, 2010 at 4:52 pm
    Did you uninstall older versions of .net? (Never do that).
    .net versions are not cumulative – that is, if you have an application that requires version 2 of .net, and another that requires version 3, then you must have both installed.
    The “Unmanaged Exception” is basically that an error handler is missing. I don’t think Ive ever seen one outside of my software development days in a prior life.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Alexandre Almeida
    September 5, 2010 at 8:44 pm
    .net framework?
    No.
    I don’t understand why the error appears always after i use Magic Bullet plugin.
    re-install it could help?
