Activity Forums VEGAS Pro Vegas Pro 9.0 Building Audio Proxy ISSUE
  • Vegas Pro 9.0 Building Audio Proxy ISSUE
    Posted by Mark Greenwood on January 6, 2010 at 5:01 am
    I recently installed Pro 9.0 64 bit on Windows 7 x64.
    I have tried several times to open a project which worked fine on Pro 9.0 32bit on a Windows 7 32 bit OS.
    The issue I have is that every time I open the project – it attempts to start building the Audio Proxy files, it completes one file – and then stops.
    The program itself is still usable – I can edit, add effects etc. The problem is that I can’t save (as the process for building audio proxys) is still going – I can’t render because of the same issue.
    It only seems to happen with certain files which came from a DV camera as AVI’s.
    I lowered the UAC on the Windows 7 to EVRYTHING OFF – thinking it was something to do with file sharing or needing admin rights. I elevated the program to run as Admin but to no avail.
    I even tried turning off Showing Waveforms which apparently is supposed to stop the Proxy files from being created but I still get the same issue.
    Does anyone else have a suggestion I can try?
    I’m a great lover of Vegas 9 and if I can’t use it on my Windows 7 as a 64 bit version I’ll be quite upset!
    Mark.
    Fraser Maclean replied 16 years, 2 months ago 3 Members · 3 Replies
  • Bob Peterson
    January 6, 2010 at 6:16 am
    Since it happens only on certain files, have you tried installing Vegas pro 9 32 bit in addition to the 64 bit version to see if 32 bit will solve your problem?
  • Mark Greenwood
    January 6, 2010 at 6:55 am
    Well I managed to get it working;-
    I just created a new project – bought all the same media in into the Project Media – let the program create the audio files, and then the next time I opened the original file, it worked.
    It must be something in the project file I guess,
    But the good news is that it’s now working 🙂
  • Fraser Maclean
    July 18, 2010 at 8:57 pm
    this solved my problem! thanks mark.
