Activity Forums VEGAS Pro Vegas Pro 9 script compatibility
  • Vegas Pro 9 script compatibility
    Posted by Paul Goelz on December 23, 2009 at 3:04 pm
    Tried to search for the answer to this but came up mostly empty….
    Just got Vegas Pro 9 and am looking into scripting. I want a script that will add a marker to the beginning of every clip on the timeline and I found one or two that seem to do that. Trouble is that they error out, mostly with “undefined variable” warnings. I suspect the problem is that they are fairly old and written for a previous version of Vegas?
    If so, how are you supposed to tell what script works for what version of Vegas…. most are not identified externally or internally.
    And to cut to the chase… anyone know where I can find a Vegas 9.0b Pro script that adds a marker to the beginning of each clip?
    TIA,
    Paul
    Paul Goelz replied 16 years, 9 months ago 2 Members · 2 Replies
  • John Rofrano
    December 23, 2009 at 7:23 pm
    Well… that’s why people buy professionally written scripts like Ultimate S Lite/Pro and Excalibur so that someone else can maintain that for you. 😉
    Internally you an tell because older scripts were written when Sonic Foundry owned Vegas and they import SonicFoundry.Vegas. Sony scripts will import Sony.Vegas. Most of the time all you have to do is change the line:
    import SonicFoundry.Vegas;
    to
    import Sony.Vegas;
    and the script will work.
    For free… this should do the trick:
     *   Program: MarkersAtEvents.cs
     *    Author: John Rofrano
     *   Purpose: This script will place a marker at each event on the selected track(s)
     * Copyright: (c) 2009, Sundance Media Group / VASST
     *   Updated: December 23, 2009
    using System;
    using System.Windows.Forms;
    using Sony.Vegas;
    class EntryPoint
        public void FromVegas(Vegas vegas)
            foreach (Track track in vegas.Project.Tracks)
                // only process selected tracks
                if (!track.Selected) continue;
                foreach (TrackEvent trackEvent in track.Events)
                    Marker marker = new Marker(trackEvent.Start, trackEvent.ActiveTake.Name);
                    try
                        vegas.Project.Markers.Add(marker);
                    catch (Exception e)
                        MessageBox.Show(String.Format("Could not place a marker at {0}\nError message is: {1}", trackEvent.Start.ToString(), e.Message), "Warning", MessageBoxButtons.OK, MessageBoxIcon.Warning);
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Paul Goelz
    December 23, 2009 at 7:40 pm
    Ah, thanks, got it. Changing that import line from Sonicfoundry to Sony did the trick. And thanks for the script too. I’ll give it a try. It looks similar to the one I had already found that now works after changing the import line.
    I’ll also have a look at your paid scripts and see if there is anything I can’t live without 😉
    Thanks again,
    Paul
