Activity Forums VEGAS Pro Vegas Pro 9 re encoding
  • Vegas Pro 9 re encoding
    Posted by Aiden Schenkels on September 20, 2010 at 12:15 am
    Hello, I am having an issue with Sony Vegas Pro encoding mpeg2 videos to mpeg2 after only making a few subtle changes such as removing parts of the video at the start and end. I need to render mass amounts of video from mpeg2 to mpeg2 with changes like this. Is there a faster way to render it or are there settings that I can change to prevent re-encoding?
    John Rofrano replied 15 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Danny Hays
    September 20, 2010 at 1:08 am
    In your Options, Preferences, make sure “Eable no-recompress long-GOP rendering” is checked and see if that makes a difference. Any effects or changing the source file will make you render every frame. But if your just piecing parts from and to the same format mpeg, this should do the trick. Hope this helps, Danny Hays
  • Aiden Schenkels
    September 20, 2010 at 8:42 pm
    Thanks, I made sure that the enable no-recompress long GOP rendering box was checked and it was. If I split the source file or make any other changes it will need to re-encode the video, am I correct?
  • John Rofrano
    September 21, 2010 at 10:14 am
    You are talking about two different things here. Splitting the source and editing out a section will not cause re-compression IF AND ONLY IF your output format is IDENTICAL to your MPEG source.
    If, however, you make a change like add any FX, then the video will need to be recompressed.
    The key here is not only do you have to enable no-recompress long GOP, you also have to render to the exact MPEG2 format that the original MPEG2 files are. Even if something as small as the bit-rate does not match, the entire video will be recompressed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Aiden Schenkels
    September 22, 2010 at 1:39 am
    Okay thank you very much, that is what I thought that the source files and the rendering output would have to be identical. Is there a setting or option that will automatically adjust the encoding settings to match those of the source video? Or is it completely manual? Also would there be any difference between MPEG2 codecs? I know Vegas uses the Main Concept MPEG codecs…
  • John Rofrano
    September 22, 2010 at 10:16 am
    No, it’s completely manual which makes it impossible at times to match.
    There shouldn’t be a difference. Vegas is looking at things like resolution, GOP, bit-rate, etc. that should be the same regardless of who’s MPEG2 codec you used.
    ~jr
  • Mike Yoneda
    April 19, 2011 at 3:54 am
    If I just do some trimming and add chapter marks, do the chapter marks counts as Video FX and cause re-encoding?
    Mike Yoneda
    Mililani, HI
  • John Rofrano
    April 22, 2011 at 11:39 am
    [Mike Yoneda] “do the chapter marks counts as Video FX and cause re-encoding?”
    No, chapter markers should not cause a re-encode. They are either stored as meta-data or kept in a separate file.
    ~jr
