Activity Forums VEGAS Pro Vegas Pro 9 Crashes on render
  • Vegas Pro 9 Crashes on render
    Posted by Rico Mancini on March 16, 2010 at 7:51 pm
    Whenever I export video in sony vegas it crashes.
    Here is the error message I receive.
    I am not sure what is causing it.
    Any help is appreciated.
    Thank You!
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 9.0c (Build 896)
    Problem: Unmanaged Exception (0xccccffff)
    Fault Module: C:\WINDOWS\system32\kernel32.dll
    Fault Address: 0x7C812AFB
    Fault Offset: 0x00012AFB
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 9.0\vegas90.exe
    Process Version: Version 9.0c (Build 896)
    Process Description: Vegas Pro
    Process Image Date: 2009-10-26 (Mon Oct 26) 15:41:04
    Chuck Pullen replied 16 years, 5 months ago 2 Members · 1 Reply
  • Chuck Pullen
    March 17, 2010 at 1:32 pm
    While the only suggestion I can give you is to send a copy of the error to Sony support to see what comes back, and also check their support pages, I can tell you that you are by no means the only person experiencing problems with Vegas. Version 9 has given me more headaches than all of the other versions COMBINED! It crashes on a predictably frequent basis, it takes multiple attempts to render files, print to tape, etc…. I’ve spent the last year planning and building a 64 bit system specifically for Vegas 9; Windows 7, Premiere, all of my other programs fun MAGNIFICIENTLY, yet Vegas 9.0 is just a huge disaster. I’m going to give Sony a few months to get it together, then I may consider migrating away from Vegas for the first time in my many years of editing…
