Vegas Pro 8.0: Using All Cores
Posted by Paul Morris on September 5, 2008 at 8:22 pmHi, I can’t find a conclusive answer to this.
How do we know if Vegas is using all cores? And, how do we set it to do so?
Thanks a lot,
Paul.
Jeremy Rasnic replied 18 years ago 4 Members · 5 Replies -
John Rofrano
September 5, 2008 at 9:14 pmIt does by default and there is nothing you need to set. When it needs them it will use them and when it doesn’t it won’t.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Rob Mack
September 6, 2008 at 6:01 amI’d probably say that it uses them when it can rather than when it needs to.
Rob Mack
John Rofrano
September 6, 2008 at 4:53 pmYes, “when it can” is more accurate since you need to have a task that can be distributed across multiple threads or processes in order to take advantage of multiple cores. Not all tasks can be.
~jr
Jeremy Rasnic
September 7, 2008 at 7:53 pmJR is right unless you have over 4 cores. If you do, you can change this by clicking on Tools/ and shift clicking Preferences. Once there, you will see a new tab called Internal. Be careful that you do not mess anything up while in there poking around.
By the way, Vegas will only utilize up to 4 cores in a beneficial way. Anything over 4 will actually prolong your render times.
j razz
