Activity › Forums › VEGAS Pro › Vegas Pro 8.0 & On2 Flix Pro – Best Settings?
  • Vegas Pro 8.0 & On2 Flix Pro – Best Settings?
    Posted by James Curci on February 15, 2008 at 4:00 pm
    I’ve been reviewing multiple posts debating best approaches to compress/convert .avi to .flv and have decided to download ‘trial version’ of On2 Flix Pro. Here are my questions?
    Despite the ‘X’ through the middle of the screen, can I assume what I’m seeing is what the full version will provide (or is the trial a step below)?
    Also, and more importantly, what is the best approach both from a rendering from Vegas perspective and a conversion perspective within On2? I’ve seen recommendations for a 320X240 format, multiple file types such as Quicktime vs. staying with .avi, Mono sound, MPEG4, etc. It all seems a bit intimidating because preparing files for the web is brand new to me.
    Any recommendations or best practices would be much appreciated!!
    James Curci replied 18 years, 7 months ago 2 Members · 2 Replies
  • Rick Wise
    February 15, 2008 at 11:35 pm
    I’ve been using On2Flix Pro for some time and recommend it highly. As far as I know (I could be wrong) the watermark X is the main difference between the free trial and the full version. There is one other difference: the free trial won’t let you both render your file to FLV and also make a SWF player.
    I have found for web posting, you have to weigh speed of play vs quality. Compromises, compromises. The On2 settings I’ve been using are:
    –File tab: default preset of 512 (VP6E-FLV)
    –Vid tab: Video dimension: maintain aspect ratio; width: 320 (but when I put the SWF player on the web page I increase the width to 550 which makes the video play larger without increasing the file size though with some loss of quality); encoding mode: 2-pass; Rate Control Mode: VBR; max bit rate: 440; everything else as defaults
    –VP6 tab: click on “enable”; use defaults
    –create player icon (little TV or monitor): click on “export player while encoding”; select player from list on left; click on “close”
    –on File tab, click on “encode”.
    Note: I render in Vegas to an avi file, best quality. I then encode from this avi file to Flash using On2.
    I do not use any of the other tabs.
    Other users probably have other methods. You can see a couple of samples at: https://wisevideotours.com/sample_tours.htm.
    Rick Wise
    director of photography
    Oakland, CA
    http://www.RickWiseDP.com
    email: Rick@RickWiseDP.com
  • James Curci
    February 19, 2008 at 4:13 am
    Thank you so much for your input. Saw the response over the weekend and hope to try these settings later tonight! Again, much appreciated!!
