Activity › Forums › VEGAS Pro › Vegas Pro 8 Transitions
  • Vegas Pro 8 Transitions
    Posted by Bill Maxwell on March 22, 2009 at 10:15 pm
    How do you set the length of transitions? I like to use flash but the standard length is too long. I don’t know how to work the selections so what I do is drag and drop it into my transition point on the time line and then I click off the transition window.
    When I check my transition, its length needs to be less and don’t know the step by step process.
    Could anyone list the steps necessary so I get a better understand how to work the transitions?
    Thank you,
    Bill
    Mike Kujbida replied 17 years, 5 months ago 5 Members · 39 Replies
  • 39 Replies
  • Steve Rhoden
    March 23, 2009 at 7:42 am
    To shorten or lengthen a transition, all you do is that when
    the two video clips are overlapped and you add a transition
    to that bit of overlapped area….then to shorten or lengthen
    you simply shorten or lengthen the overlapped bit….Hope that
    is clear for you.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Bill Maxwell
    March 23, 2009 at 1:04 pm
    Thank you very much. I tried several different ways and you made it very clear to understand.
  • Steve Rhoden
    March 23, 2009 at 1:47 pm
    You’re welcome Bill.
    Steve Rhoden
    (Cow Leader)
    Portfolio at:
  • Bill Maxwell
    March 30, 2009 at 4:34 am
    I was able to find how to give a strobe effect to the video before but don’t recall how I did it. It was very simple as I recall. Do you know how to do it?
  • John Rofrano
    March 30, 2009 at 12:33 pm
    Add a Fade To Color envelope to the video track and create envelope points that quickly fade to white (top) and back.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    March 30, 2009 at 12:50 pm
    Also for added ease of use & variety…there is a plugin
    thats available for Vegas named “Pixelan CreativEase”
    that does this really well along with tons of other
    unique stuff.
    Steve Rhoden
    (Cow Leader)
    Portfolio at:
  • Bill Maxwell
    March 31, 2009 at 4:06 am
    I will give that a try. Not sure exactly about the envelopes on how you make them but I will try it the way I think it might work.
    Thank you,
    Bill
  • Bill Maxwell
    March 31, 2009 at 4:07 am
    Thank you for the information.
    Bill
  • Bill Maxwell
    April 5, 2009 at 11:06 pm
    John, do you know how to put the mask on the video and then put the name of a person over the mask. I think I’m calling it by the right name but it’s the thing they do on the news when they are talking with someone and then they put the person’s name with his or her title up for 10 seconds.
    Is there an easy way that this can be done?
    How do you fade it in and fade it out?
    I know how to do it doing analog editing and we called it super in and out and you would use a character generator and then bring it in and then out.
    Another thing is how to stations put their logo on the entire piece of footage that they show? Just like youtube does the same thing.
    Any help would be appreciated.
    Bill
  • John Rofrano
    April 5, 2009 at 11:24 pm
    This is called a “Lower Third” because it usually takes up the lower third of the screen. The easiest way to make them is with Solid or Gradient Generated Media, or any animated or static media background of your choice. You can go into Pan/Crop and simply resize it with the Lock Aspect Ratio off to squish it into the bottom third, or use the Bezier Mask to make any shape you’d like. Use one track for the lower third and another on top of it for the name text. You can fade them on and off or push them on and off, etc. by adding a transition to each end of the events.
    ~jr
Page 1 of 4
